Hi
i have a rectangular driver , approx. 6.5 x 16.5 cm and would like to build a horn with le cleac'h or oblate spheroid flare ,
but i cannot find a le cleac'h or oblate spheroid calculator for a rectangular throat horn .
i got a tractrix spreadsheet for rectangular throat .
can anybody help ?
thanks
can anybody help ?
thanks
OS is only round. If you just want the flare rate then its
y(X) = sqrt( y0^2 + Tan(theta)^2 x X^2)
y0 is the throat radius and theta the final wall angle (which will usually be at the -6 dB angles)
theta is the half-angle of the wall-to-wall angle, I presume; i.e. from center line axis to wall?
Hi
can anybody help ?
thanks
Hello,
Hornresp can calculate both OSwaveguide (round) and Le Cléac'h horn (even mutlifacdts an square).
You then can export the profile.
You may also use the english version of my spreadsheet to calculate Le Cléac'h horns with facets. You can download it at :
http://forums.melaudia.net/attachment.php?aid=2310
Best regards from Paris, France
Jean-Michel Le Cléac'h
- Rectangular Throat Horn Calculator / Spreadsheet for Le cleac'h and Oblate Spheroid
