Replacement for NE5532
the first PDF schematic (post #5) under
Head Pre for Denon DL 103
shows an interesting approach from Tim de Paravicini with the NE5534 for a RIAA head amp.
Maybe usable also for other applications like line gain stages and active crossover networks.
Quite, but (if I am looking at the schematic that you are referring to) - you will know that the SSM2210 and LM394 dual transistor parts are now both obsolete and increasingly hard to find.🙁
The specs (typical) from data sheets are practically identical. The block diagrams also. (the TI 5532s). But there are always variations in semis. That's why most parameters have typical and min/max values. What yours actually are is a crap shoot. So if one batch has close to max noise and the other is below typical there's a difference. The next 2 batches from those manufacturers may be the other way around. And then there's always counterfeits. But I'm also skeptical that you would here a difference anyway.
Edit. Some of these variations are huge. Input resistance 30 to 300k, CMRR 70 to 100 db!
Edit actual could be bigger because the 100db is the typical value. 70 is min what's max 110db ?
