Rohde Schwarz R&S UPL Audio Analyzer Renovation.
That’s always a good idea to have a backup on hand.
The files are still recreated from the EEPROM when the files are not found (new hdd/format).
But still, better be safe than sorry.
I also made a backup of the diagnostic menu parameters in case i would ever need to re-enter them.
Oh, one thing I recommend doing before any mod is to save the cal files.
Easiest way is via the Floppy drive already in the unit, a 1.44MB is more than enough.
Scandisk / format first the diskette, to be sure you have a usable media.
There are 10 .cal files.
In DOS prompt,
Code:cd C:\UPL\REF copy *.cal A: /v
and that is all. You can do 2 - 3 backups onto several diskettes just to be sure.
Floppies are still OK to use for small tasks. I keep them in a tin can just to be sure.
Just to see how they cope, kept some near a tweeter (5cm) and above a woofer (15cm) and they still work fine with no disk errors.
Going to use the CF Card on the motherboard to performe a clone of the HDD, not sure how this will work.
I stopped bothering with cloning. The installation of dos and UPL goes fast anyway. Cal files are copied from EEPROM. So other than personal files you can backup there’s not much else to backup.
You don’t want to know how many times i did this routine in production environments where units stopped responding and after a reinstall they magically worked again. Granted the hdd was probably starting to fail at that point.
With the new motherboard you can hook up the analyzer to the network and via ftp load files from and to it. Goes much faster than floppies or even emulator for that matter.
Bart
However having said that. That was mainly due to slow HDD and lack of IDE adapters and tools.
Now that i’m using CF cards, i am backing up images a lot more frequently since the process has now become extremely easy and fast (my image backup or restore takes 10 seconds).
But still it’s mainly to get the baseline of a freshly installed system, not to preserve CAL files or backups. I have those backed up separately.
Bart
Bart
Bart
I have DOS 6.22 Floppies 😀
Haven't heard those sounds for more than 15 years. Let me enjoy
That sweet floppy sound... ;-)
Enjoy!
Wondering if FreeDos can be put instead of MS
I did also, but never tried it.
Are you up for the challenge?
I will try some OS variants next week. Still waiting for the CF cards and adaptor.
FreeDOS might break some runtimes if the UPL is based on MS tricks
Great,
Exciting to hear!
Right, so my whole edit post failed.
HDD Smart data seems OK. Power on count is not reliable. Starts from 0 with every reboot.
HDD Read speed 2MB/s
HDD Write speed: 2MB/s
avg Read / Write speed: 0.9MB/s
avg Seek: 12.6ms
avg Access: 21.6ms
Guessing the interface between the HDD and the CPU motherboard is the main culprit.
Bart, you said there is no way to use the CF on the motherboard for UPL duties?
avg Seek: 12.6ms
avg Access: 21.6ms
Hint, for the UPL you can program a RAMDisk, with these new boards as Memory is 128MB.
Just had a quick go at windows 3.11 but it also does not seem to run the UPL out of the box and would require some tweaking.
Unfortunatley my knowledge of these OS's is far too limited.
Would love to some progress by others, especially with network working 🙂
Good luck,
Bart
þ Average Seek Time: 12.8 ms
þ Maximal Seek Time: 23.6 ms
þ Track-To-Track Seek Time: 6.0 ms
þ Average Access Time: 21.3 ms
Read (MBytes/sec.) Write (MBytes/sec.)
þ Linear Speed At Track 1: 2.0 2.0
þ Linear Speed At Track 787: 2.0 2.0
þ Average Linear Speed: 2.0 2.0
þ Min. Linear Speed: 2.0 2.0
þ Max. Linear Speed: 2.0 2.0
þ Max. Cache Read Speed: Not Determined
þ Random Read Speed: 0.9 MBytes/sec.
avg Seek: 12.6ms
avg Access: 21.6ms
I never got it to work as a boot device.
However i had suspicious CF cards at the time.
Better to try it with a good CF card.
Spent last hour reading about the HDD accessing.
At the moment I am experimenting with some DMA drivers. HDD speeds are not changed, however I got 64MB/s cache speed, from the previous NOT SUPPORTED.
Can't be sure, might be Placebo, but the FFT at 8192 seems to be faster at refreshing. And the speed which the interface loads.
Interesting find,
I’ll try to get windows 95 working today.
I am curios about Windows as well, it should provide better IDE DMA drivers. Hopefully the HDD/CF wont be stuck in PIO mode 0.
The Fujitsu is actually capable of 3-4MB/S.
- Design & Build
- Equipment & Tools
- Rohde Schwarz R&S UPL Audio Analyzer Renovation
