I have a Rotel RX-802 which has some issues with the phono-in and some scratching in the right channel when I adjust the volume; deoxiting the connections and pots didn't fix this. Also, both of the phono ins of the 802 have some pretty severe distortion on both channels and in addition to this, the right is much quieter. In general, from all inputs there's humming in both channels but the left channel has a higher-pitched hum than the right channel. There's nothing wrong with the aux inputs except for this hum.
As a result, I think it's some transistor on the pre amp or power amp boards of the RX802, but I'm not sure where to start diagnosis and how to fix this. I'm having trouble figuring out which boards I need to look at and which I don't need to touch. Some help would very much be appreciated. As the title says, I want to do a refurb of the pre-amp, power amp and power supply sections of both receivers at once to allow me to bulk-purchase caps and transistors despite there being nothing wrong with the 930.
