started matching of 2SK1530/2SJ201
Transistors are placed on the hot plate with 65C. IV curves are taken using locky_z's curve tracer.
2 very well matched K1530 at 65C!
price for non-matched 1530/201 pairs, if possible ?
TIA
Non-matched pair will be available once I finish the matching will need every transistors to make the population as large as possible to get more matched pairs first
Non-matched will be usd18 per pair. Thx
matched NNNN and PPPP at 65C~~~
typical NNNNPPPP matched curves (red curves are 201). Matching is not as good as I expected due to most K1530 are having larger threshold voltage than 201. I lowered the price significantly due to this imperfection. I only found 3 pairs out of 1200+ devices measured...hopefully can find some more...this kind of yield can not recover the costs of all these FETs...
I would be interested in matched 2SJ313s only (2 pairs for a "reloaded" Aleph 30). if you have them among the spares after matching to the complimentary, I would appreciate it. you can PM me. Thanks.
Hi koja,
Sure. Will inform you once I finish matching.
pls refer to the link for 1530/201 grade A and A+ matching sets
https://drive.google.com/file/d/0B7I-t5z7GgxRTGlURTRXdTdjR2s/view?usp=sharing
Only one set grade A+ available
k170GR matched Octal
interest check: anyone is interested in matched IRFP240/IRFP9240 from Vishay? probably NN-PP kind of matching rather than NP matching, considering the performance different from datasheet. Anyway, these are cheaper alternative of 1530/201 for some amp. just want to check whether it is worth the effort of matching them.
30 pairs of matched 170BL ready to deliver
5 matched 2sj313
Hi fab,
Here are some IV for 2013. Haven't really sort the data yet.
Hi fab,
prices have been updated in the first post. thx
Looks good!
I suppose that If I do not need matching the price will be less once established.
Fab
Matched 2SK246/2SJ103. Only Idss matching sets are available. Note: Vgs for 2SK246 is inverted in order to show the matching CV is NPFETs
- Vendor's Bazaar
- Selling Zhou Fang’s remaining stocks including some very rare Toshiba transistors
