I am designing a 300W car amplifier using TAS5630B. To power the chip I am stepping up the 12V input to 40V DC using push-pull topology. My controller chip is SG3525 and I am using a PC40 material T28X16X16 size torroidal transformer.
For SG3525, I choose Rt= 22K, Ct= 1nF and Rd= 56 Ohms. Which gives oscillator frequency of 64KHz. So each MOSFET is switching at 32KHz.
My question is during calculation of primary turn of torridal transformer which frequency, f I have to consider in the formula Npri= (VinX10^8)/(4XfXBmaxXAc) ? 32Khz or 64 Khz ?
Your formula looks strange, for me it's Np = V/(4*B*F*A), with all units in a coherent system, for example V in volts (across one half primary), B in Tesla, F in Hz and A in square meters, but maybe it's just the way it is written without a formula editor.
The frequency you need to take into account is that seen by the winding, in your case 32KHz.
Note that this formula is only valid for steady-state conditions. Without any particular precaution, the core will see a ~doubled induction during start-up, which might kill the active switching elements
Thanks Elvee, both formula is correct as in my formula B in gauss, A is in sq cm.
For my application (push-pull), Dont you think the winding is actually seeing 64Khz as it will see both switches, each running at 32 Khz ?
Can double induction could be prevented using soft start ?
NoFor my application (push-pull), Dont you think the winding is actually seeing 64Khz as it will see both switches, each running at 32 Khz ?
YesCan double induction could be prevented using soft start ?
No
Yes
The two switches are creating flux alternately, each at 32Khz. So the core itself sees 64 Khz. Appreciate if you explain why its 32Khz. 🙁
I created this push-pull transformer calculator from a Linear Tech datasheet -- you'll have to save it to your own device to get it to run in anything but "Read-Only" mode:
http://www.tech-diy.com/smps_xfmr.xls
My friend, when one is so certain of his reasoning, no argument can helpThe two switches are creating flux alternately, each at 32Khz. So the core itself sees 64 Khz. Appreciate if you explain why its 32Khz. 🙁
the cores flux density is bi-polar, so the max level is calculated for each half cycle. volt *seconds per turn / core leg cross sectional area. so at the end of a complete cycle eg 64KHz, the core flux is reset to zero.
the key is to think in terms of volt*seconds instead of plain old frequency.
now it makes sense! So I should use 32Khz in equation.
BTW, I didn't understand the equation how you calculated Bmax for each half cycle. Is it, Bmax=(V*Time)/(Npri*Ac) ?
What is the units of each of them?
I just remember it that way,
iregardless of any constants, waveforms, etc
Re units, I just use faradays law and the integral > area of the voltage drive
thus units come into play only for Bmax and Ae from the cores data sheet.
now for core losses, use double Bmax for one complete cycle > delta B
from http://www.ti.com/lit/ml/slup123/slup123.pdfthe flux change is proportional to the
integral volt-seconds per turn (directly equal in the SI
system). Faraday's Law operates bilaterally -
Thanks NEC3. The explanation is very nice.
flux doubling concerns using voltage mode controllers
from http://powerelectronics.com/site-fi...cs.com/power_semiconductors/Feature2_0309.pdf
This phenomenon is known as flux doubling. To avoid this,
soft-start the converter and employ a cycle-by-cycle current
limit, which will terminate the cycle and restart the converter
in a transient conditionsoft-start the converter and employ a cycle-by-cycle current
roomi, the output inductor of a push pull will see the 64khz, 32khz x 2.
Yes. But I am not using any output inductor, only capacitors.
The transformer ferrite will see 32 Khz 🙂
This phenomenon is known as flux doubling. To avoid this,in a transient condition
Very informative document ! Thanks infinia. 🙂
hi all just use this software
IR2153 SG3525 Frekans Hesaplama Programları | Elektronik Devreler Projeler
https://320volt.com/wp-content/list/21728.zip
have fun all
have fun all
- Power Supplies
- SG3525 ferrite transformer calculation
