So you think you know better?
Crossover parts are expensive, which is why all but the most exotic are cheaper than the designer probably wanted.
Ironically small capacitors are cheap enough, but that does not stop the manufacturer's cost cutting department from forcing both the size and quality down a notch from what the designer would have liked when the unit is put into production. By default I check the calculations for the 'as built' design and adjust values accordingly, whilst selecting the appropriate capacitor type for the task in hand. I don't see that being much different to loudspeaker crossovers. The gains may not be as big perhaps as a typical well considered crossover upgrade, but there frequently are significant gains IME.
Designers are after all human; they have blindspots, favourites, prejudices, sometimes smugness, and like the rest of us make mistakes too. I have a long list of design faults I have found over the years in consumer and professional audio equipment, and price or company reputation is no barrier to faulty design.
Where possible I have always tried to communicate those findings back to the designer. Often they have been very grateful, but every now and then there's one who couldn't give a rats and isn't going to talk to someone who challenges their (self perceived) godliness. For example there's a certain high-end phono stage in which I discovered an earthing design fault that caused noise in some setups. When raised with the designer he fobbed me off, yet the Mk II version had the modifications I had devised and sent to him. Another designer was very grateful when I discovered the reason for an extremely low level sizzle noise in a high-end valve preamplifier caused by a trimpot used for setting bias. The designer didn't know he had exceeded the current rating of the trimpot and had just been replacing the trimpots under warranty as needed.
