Soft Start module: when do you use them?
Joined 2004
I see a lot of builds without a soft/slow start module. Who is using them and what size trafo/cap bank do you use them?
I also see a lot of builds without speaker protection circuits/boards. Same question: when are people using them?
Thanks!
Greg
I use a mosfet cap multiplier to feed my CRC - takes about 20 seconds to reach full voltage. No thump. Main reason is to prevent smps from shutting off due to it thinking caps are a virtual short. Look for Juma’s Easy Peasy Cap Multiplier thread. Only problem is loss of 4v headroom on smps or trafo.
Around 50 - 100VA I'm happy with nothing; in the 300 - 500VA range I use CL60s.
With the larger transformers I've usually got around 150,000uF and a cap multiplier, or around 250,000uF straight up.
I haven't put speaker protection in any of them.
