Which is the best soldering iron and desolder for PCB works under 100 dollars/euro? I should consider cheaper options from AliExpress?
@markbakk
I am just a hobbyist, and I do soldering just for some projects; otherwise, I don't use that much, so I should go with this model. https://www.atten.eu/product/1128218/atten-st-2065d-65w-soldering-iron
and buy a desolder from AliExpress? or both from AliExpress because atten is also available in AliExpress.
Current production entry-level Wellers are over budget and in my opinion less capable than the old workhorses of the past like the Weller WTCP-S. Those old soldering irons are occasionally available for less than 100 EUR on the second hand market (note that the expensive part is the soldering stylus, not the power supply; check the listings carefully). WTCP-S is still my favourite soldering iron at home. I also have a new soldering iron with the T12 tip system. There are more specialized surface-mount tips available for T12 than for the old Weller, the temperature control is better, and it heats up faster. I paid it less than 50 euro for it with several tips from AliExpress. The ergonomics are worse than the WTCP-S or any professional quality soldering iron, and it is not suitable for working on large parts that require more heat. My home desoldering station is a model 985 from China, readily available from major ecommerce sites. It does not compare with the "real" one I use at work, but it is enough for occasional use.
WTCP-S is the one I use over 33 years now, replaced the inside of the soldering iron once, it is rock solid and was an good investment!Current production entry-level Wellers are over budget and in my opinion less capable than the old workhorses of the past like the Weller WTCP-S. Those old soldering irons are occasionally available for less than 100 EUR on the second hand market (note that the expensive part is the soldering stylus, not the power supply; check the listings carefully). WTCP-S is still my favourite soldering iron at home. I also have a new soldering iron with the T12 tip system. There are more specialized surface-mount tips available for T12 than for the old Weller, the temperature control is better, and it heats up faster. I paid it less than 50 euro for it with several tips from AliExpress. The ergonomics are worse than the WTCP-S or any professional quality soldering iron, and it is not suitable for working on large parts that require more heat. My home desoldering station is a model 985 from China, readily available from major ecommerce sites. It does not compare with the "real" one I use at work, but it is enough for occasional use.
There was just a big thread/discussion on soldering iron recommendations: https://www.diyaudio.com/community/threads/lifespan-of-your-soldering-irons.419021/
I have used an ANtex TCS50 mains powered 50watt thrmostatically controlled iron for over 20years and wouldn't use any other. They are reliable and easy to adjust the temp if neessary, + wide range of tips.
https://www.antex.co.uk/store/p/m12-w9wdk-mg96e-y7lr5-wh7k3-t9ktb
Thanks for your suggestion. I was also looking for WTCP-S for the past few months, but it's very rare to find in full kit. but I will search for it.For soldering you could also consider active tip systems. Do not own one myself, but they are the way to go. As a brand Fnirsi pops up. Staying traditional, Hakko has to be mentioned too, a long-time price performance winner. But over budget a bit.
- Design & Build
- Equipment & Tools
- soldering iron recommendation
