Proac are a little mean on what they divulge, so I thought I would share a little of my hard earned knowledge, and give a kind of database of proac info for fans and curios
for some great proac klones check this out.
http://audioclone.free.fr/scanspeak.html
Older proacs are divided into 3 ranges,
1/the tablette
2/studio
3/ response
tablette 3, 50, 2000 inc. signatures use seas woofers and seas or scanspeak tweeters...2010 on signatures.
further info added: tablette ref. 8 still using seas bass unit, but treble is now changed to vifa tweeter, these appear to be oem units.
xover is still the std proac seas type, 2nd order on bass, with rlc across woofer, between the inductor and cap.
cabinets do not feel as substantial, terminals are cheaper too, but it is true to say after listening to the 3s, 50s, and ref. 8s, that in every incarnation, they have subsequently sounded more open, better bass and clearer mid, so it would appear they get better with every new model, and its not hype.
studio 1, 100, 200 use scanspeak 8543 paper woofers and seas tweeters
studio 125 are like the tablette 2000, and use seas woofer
studio 150 use seas p14 woofers, and scanspeak 2008 tweeter.
studio 200 and 250 use the 8543, like the studio 1, in the 200 they are in a dapplito and the 250 there are 2 of them, not sure if a 2 or 2 and a half way.
response 1s use seas t14 woofer, scanspeak 2010 tweeter
1sc uses a different woofer.
reponse 2.5, well you know!!
reponse 3 and 3.5 both scanspeak polypropylene woofers, scanspeak 9000 series tweeters
apparently, the r3 cones were made by rogers, and were changed for the 3.5. They are plastic coned.
response 3.8 uses 2x 8535 woofers, 9300 tweeter
response 5 2x8535, atc mid, 2010 tweeter
response 4 atc 9 inch short voice coil woofers, atc mid, scanspeak tweeter.
response 4 crossover is 2nd order bass, 2nd order on the mid(lower and upper) and 2 order on the tweeter, a departure from the normal proac xover.
response d150 and later proacs are now using volt woofers, and some using scanspeak tweeters.
You see a lot of the drive units are similar, the favourites are seas woofers, usually the plastic polyproylene cone: t14, p14 or p17....in the seas woofers, the letter is the cone material, t for TPX a kind of plastic, p for polypropylene, L for aluminium, and the number is the diameter in cm,
and the tweeters usually scanspeak 2008 or 2010 tweeters, and there is really little distinction between the ranges, the tablette are the small ones, some studios are uprated tablettes:
the studio 150 is like the tablette 50, studio 125 is like the tablette 2000.
Studio 200 are the same as the studio 1 or 100 just another drive unit and bigger cabinet.
response d15 is like the tablette 2000 signature: same drive units, bigger cabinet.
response 2.5 is like the studio 125 only different drivers which is the floorstander version of the tablette 2000
Proac seem to favour a d'appolito configuration which is used on studio 150, 200, response 3, 3.5, and the latest responses.
crossovers: the standard proac crossover is 2nd order in the bass, 3 order in the tweeter, with one attenuation resistor as the first component in the tweeter. No L-pads here.
They are in phase, but the components are the opposite way around, ie in the negative path rather than the positive.
With the 2.5, the bass is 3rd order,a change for proac with a 47 ohm resistor across the first inductor.
The 3.8 crossover is 2nd order on the bass unit, at 300 hz, and the rest I think is identical to the 2.5 ie 3rd order midbass, 3rd order tweeter.
With the scanspeak woofers, no resonant filter is used, but with seas, a series RLC circuit in that order R, then iron core L, then C is used, ACROSS the woofer. The bass signal first passes through the series inductor, THEN comes the RLC, then the parallel capacitor...check this out for a typical proac crossover:
http://audioclone.free.fr/responseONEsc.html
The cabinets are lined with bitumen and acoustic foam, terminals are michell rhodium plate.
with the crosovers, the FINESt components refers to air coiled inductors, solen capacitors, and ceramic resistors. Pretty standard, and some standard multilstrand cable, a la qed or bandridge.
latest response d100 uses Volt 2500 type woofers, atc mids.
series RLC on the seas woofers comes after the bass inductor but before the parallel capacitor.
Values are typically: 4.7 ohms for the tweeter resistor, 5uf cap, choke, 6.8uf cap
woofer: choke, 10 ohm resistor, choke, 20-40uf cap in parallel with woofer, 5uf cap parallel with woofer.
that's about it, good luck....data by name, data by nature.
all this has been written in the belief proac are mean with their specs they divulge, and it ought to be in the public domain.
Its a shameful practise when you see the specs. some makers give, especially in the pro audio domain.
IMO there is no need for it, as proac use custom drive units largely, so no one can reproduce the designs at home.
Also, I consider Mr proac a minor genius, he manages to produce excellent speakers, and interestingly they all sound similar, despite having differing drive units, I supsect its a lot in the xover design, which are frighteningly similar on all the speakers. Minor tweaks are obviously the way he designs.
Speaker cabinets are made by the castle factory, and I have heard the xover boards are by bk electronics, who used to make the amplifiers for rel subwoofers.
1/the tablette
2/studio
3/ response
Disabled Account
Joined 2003
I couldn't find information on the Response 3.8 on your website...
do you have any more information?
Page 41 of Troels Gravesen's 2.5 Clone paper reveals why ProAc speakers tend to sound similar despite using different drivers. The tonal balance is slightly U-shaped, with a "persistent increase in bass and treble response as seen from the ProAc speakers combined with generally recessed midrange."
It's a very engaging kind of sound and makes for rather exciting listening (or first impressions)
I once compared side by side a pair of Vandersteen 1C speakers to a pair of ProAc Studio 125. After about 15 mins with the 125, the 1C sounded rather boring in comparison, even though its tonal balance was probably more linear.
hmm, its not my website, I was a student and enthusiast of proac, having owned and dissected many and learned about them.
I thought I would share a lot of what I learned.
the 3.8s are a 2 and a half way.
They are like the 2.5s, but with an extra 8535 woofer, and a bigger scanspeak tweeter.
The bass rolls off around 300 hz with a 2nd order filter I think. may be 3rd, can't remember.
then the rest is similar to the 2.5 ie 3rd order bass/mid to 3rd order tweeter.
Proac have an extremely and addictive, musical sound, slightly bright, but they are just so right. Others may be as good or better, but proacs do have some magic to them.
ProAc studio 140
Hi there, all of you proAc fans... I wasn´t, but became a recent convert when looking for a nice, not too expensive and wattage demanding children-proof floostander...
This is my first post so bear with me ... Ok, so what am I looking for?
Has anyone taken a peek inside th Studio 140s? I was a bit surprised-not very good components, no bracing whatsoever, ans that box plays along , believe me..
So I am thinking of upgrading.
First I will deal with the crossover. Does anybody have the values for the chokes( they have nothing written on and I don´t have the equipment or knowledge to measure them)?
The tweeter uses a single cap , I think to be a bipolar electrolytic,from Expotus with 6,8K100V written on it. Is this a 6,8 milifarads cap 100v rated? The tweeter is the weakest point in my view - not very transparent or extended, and hardens up when pushed - It is soo much worse than my dad´s very old and inexpensive wharfedale 505.2 that it is embarassing.
~So I am looking for a lush but very transparent and extended treble. What do you reccomend I substitute this cap for, and where can I get it?? If it is a 6800 milifarad cap I will probably have to use some kind of bypassing, some I would appreciate your advice on that too.
I will make other upgrades too, and have altered the bass alignment a bit, wich worked excellent for my smalish room and might be of interest to you.
I will post the crossover scheme and a crossover picture, or you can contact me at fmapinto@gmail.com.
Thanks for your help
hi yes I am afraid proac do use cheapish components.
I doubt very much there is one tweeter capacitor, only in a couple of models its 2nd order, its probably 3rd order, with 2 series caps.
I wouldn't mod them, you will destroy the value.
you can get a cheap inductance meter and measure the chokes. be accurate enough.
proac have barely ever done anything new, its the same old crossover with a few little tweaks, and the same with the drive units, same formula, little tweak each time, and seas drivers. I think one xover is just plugged in and the values altered a little.
to think I used to see stewart tyler as a genius.
I wouldn't be surprised if he got the xover from wharfedale, kef or celestion or someone else.
but it works, and they do have some magical properties if they work, trouble is, they are a bit bloomy in the bass, recessed mid and squeaky at the top.
sadly the info manuals are insulting, no info at all, if you are paying that money, you deserve info, just look at a professional audio company, some of these hifi companies treat buyers with contempt, it shows they aren't totally pro in attitude.
Mr tyler also uses slightly modded drivers, so I don't know what he's worried about people knowing, pros could easily discover the 'secrets', and amatuers can't 'clone' non standard drive units.
With due respect, why on earth should a manuafacturer give people like you the free licence to rip off their products and devalue their work?
The new Proac boards are an opaque triple layer sandwich construction so people are going to have even more fun trying to work out what Stewart has been up to.
I don't know how they make those speakers - but they sound so much better than what they should according to components inside. I have built ProAc Clone hoping to upgrade from Studio 125, and it did not come even close. Studios kicked Clone's a** in every respect, and I had top notch components in Clones. This was just a beginning in series of DIY disappointments, which ended with Gainclone. I am now seriously thinking in buying Studio 140 without even auditioning them, if I could only get rid of Clones somehow, they are almost impossible to sell.
Hi all,
I got a Studio 130 pair of speakers.
Plan to work on the filter as I discover the quite low quality of the components. The capacitors are a sort of unknown MKT (?) brand.
For Self values (and capacitors < 10uF), you can use Speaker Workshop if you have a PC and a quite good sound card. I compare a 1Khz Speaker Workshop measure with a professional LCR meter = less than 3% of error !
If any interessted, I can post the schematic of the filter with the values.
I plan to build a external filter and not destroy the original one.
Hint: Self = French for coil, and not Douglas Self !!! 😉
Charles
Proac uses cheap metal dome MB Quartz
Hi all,
Greeting to you all.
Your posts regarding the Proac product line has really enlighten me. Especially, it's good to know about the good quality of Proac sound, in addition with the bad. I am also very curious with upgrading an old Proac SuperTower that I have. I also found out that most of the stuff inside that they used were cheap (e.g. cable is thin Radio Shack kind, the parts were not so impressive. For example the tweeters that they used were a cheap MB Quartz metal dome tweeter that are no longer made. I found the sound of the Proac to be very typical , which is great bass, bright sound (very bright sound if not paired carefully with warm equipment -- personal experience). But in my case, the original SuperTower tend to have a very harsh & loud sound to the voice,which could lead to very fatiguing sound after long listening session. Is there anyone out there that have an idea to which soft domw tweeter that I could use to replace the MB Quartz to tame the brightness. I've been trying to find all over the web, but the only the only clue I've got was in later model MKII, they used Seas driver.
If anyone could tell me the exact model of Seas driver, I would really appreciate it. Or any idea to changing the CO, adding an L-pad???
Thanks ahead of time.
Hi all,
replace tweeter in PROAC SUPERTOWER
Hey ducchau68, did you ever have any luck figuring out which tweeter to use as an upgrade on your supertowers? If anyone else has any ideas on a good fit replacement soft done I'd love to hear them. I just got my hands on a pair of old supertowers and think they are a little bright in the high end for my taste, I'm hoping that replacing the tweeter with a nice soft dome will do the trick. Thanks DIY'ers.
Don't think that replacing the tweeter will necessarily help. I have a pair of Studio 150 in my wife's yoga room and they are quite horrible to be honest. Especially the bright highs which require a really mellow tube amp to be listenable. And there is nothing particularly wrong with the tweeter. It's most likely the crossover design and capacitor quality. I can easlily change the cheap polyesters to something better but really not sure if it's worth the effort.
TP,
Sorry been away. I never thought that anybody else would have Proac SuperTower. It is not a little bright. It is a heck of bright and
the midrange and voice comes out as very hissing and sibilance.
So the best approach is to upgrade to a different speaker. In my case, I've upgrade to the Response Series.
If not, then here are some reccommenations :
o You can wait for someone to post a Proac SuperTower II tweeter
on Ebay auction. Only problem is that it is circle shape
instead of square shape. But this can easily be remedy by
unscrewing the new round metal from the actual coil/dome and
replace it with the old square one.
o Based on some odd reccommendation from one audiogon fellow,
I actually put cotton surrounding the tweeter to absorb the
energy of the tweeter. This really help but may not be pretty.
o Third, design your own L-pad of around (-3dB). This is what
used, before it was sold.
Hi guys
I currently have dual SS9700 tweeters,dual ATC non s and dual volt 3143(12") and would love to find a good crossover for the dual mid(I love these mids).
The D100 is the only speaker that I have seen that utilizes these in a dual combo.Any help would be great.
john
john
Start a new thread (ask administrators to move your/this post and give a new name), post complete set of model/impedance for your drivers, measure them, to start modeling (get measurement data - Driver FRD & ZMA files) a new xover/enclosure. My question is, why you need two tweeters, this is, if you know how to put them (dual tweeters+dual mids+dual woofers) to work.😕Hi guys
john
As a basic designer of a speaker you should start with something someone already tested, like a basic 2-way or 3-way with single drivers, to make things easy.😀
I'm sure you can design a dual speaker, but again with only one tweeter. Now, for that, you would have to change tweeters (more SPL), pad the mids (dual) or use only one mid + one tweeter. What's your line of thinking if I can ask?
http://www.diyaudio.com/forums/mult...crossover-schematics-clone-atc-scm-100-a.html
ATC SM75-150S Dome Mid Measurement Data - ZeroGain Forum
Hi all,
Hi, just regarding the internal cables, as far as the 'original first proAC tablettes' are concerned..., I 'rewired' mine, with thin silver strips, ie: 5mm x 0.3mm strips for mid/bass, and 5mm x 0.15mm for tweeters ...; as well as using mundorf silver solder..., the transparency did improve to a noticeable degree, as did the dynamic clarity, however I did notice that the original wiring was rather good, and was silver plated copper...., which I could have left on the mid/woofer and just changed the tweeter wiring, but yes....they are quite good for vocal imaging....I am really having to restrain myself from changing the caps to 'ansar solid silver supersounds'...
I have just rewired some ARCAM II's with silver strips for tweeter, and military grade Teflon coated OFC silver plated for mid/woofer, and rolled over the crossover with 'ansar' SS caps; and the transparency, imaging, clarity is unnerving --- although I don't have my ProAC's with me (in storage), I just feel the ARCAM II's now will surpass them, or at least be on a even par with them --- with their own 'signature' however, but soooooo gooooood sounding...., cannot stop listening : I want to just kiss the (female) vocalists lips that just 'appear' *sigh* --- sad in a way (with regards to ProAC's), but exciting.... 🙂
...to be fair, I really need to compare the ProAC's with the modded ARCAM II's, however, I feel they will hold their own on an even par with their own unique signature ...
I am also using silver 'coated' speaker cable, in a 4 core - wire balance, with silver plated speaker input terminals, so there is silver all the way...
....ohhhh, please do try the 'ansar supersounds' with the solid silver terminals..., and use solid silver strips (annealed @ 300 deg C for 1 hour in oven) with mudorf silver (lead free) solder with gold traces...
...and give us some feedback 😀
I love my Studio 125's, so I thought I would treat them to some better quality crossover components. I also rewired them with some better quality cable - QED Original. the sound changed for the better - the balance was the same, but the sound was simply more musical and more controlled in the bass. The change wasn't massive, but enough for me to stand back and hear more in the music than before and that makes me happy 🙂 After 14-years with the 125's, I would like to upgrade to the Response D18's, but I wonder if it's worth it - anyone have experience of the difference? pics below of crossovers:
Original components:
http://s769.photobucket.com/user/wiland2007/media/IMG_1744.jpg.html
[/URL][/IMG]
New components:
http://s769.photobucket.com/user/wiland2007/media/IMG_1749.jpg.html
[/URL][/IMG]
Will
New components:
Will
sorry - here are some lower res pics (it won't let me edit the original post):
Original
[/URL][/IMG]
New
[/URL][/IMG]
Original
New
It seems that ScanSpeak woofers need a long time to break in. The best thing is to keep them connected 24/7 on a signal generator 100Hz/2-3V for several days before making cabinets.
- some proac info. look at this everyone
