Beautiful project.
The "Amati Clone Project" link on your first page is to my own site , so I couldn't resist a comment!
I never started building the project I described, partly because I was (and still am) happy with my previous speaker project, and partly because the Amati build would have worked out very expensive with the drivers I judged to be the closest match to the ones used by SF in the original.
It would be very interesting if you made up an article on the web about your project, discussing your reasons for choosing the drivers you used (quite different from the ones in the Amati in many ways) and describing the crossover design process and the build (though your great photos indeed are worth many words!).
How do they sound? You didn't mention that...
By the way, I built my own speakers in a small spare bedroom in our old house with the minimum of woodworking tools.
Alex
Hi Alex.
Sorry for the delay in responding, I am among those who talk too much and my Inglés being bad , so my comments are limited
I'm using the google translator.
I made a mistake in my project and i will solve soon ,the first woofer that cuts on the 350 hz should I replace it with a Scan-speak 22W/8534G; This will give me perfect linear response by to have a little more sensitivity.
You can even observe that my nominal impedance is 8 ohms total . I spent about three months to complete my crossover,...I am of those who I will not take the first solution view ..... so my exploration was to the JBL Everest , and take the concept to cut the two woofers in a masterly manner, and strengthen the area of 60 hz down where all speakers have this weakness.
JBL Everest DD66000
From what I've learned is that care must be taken in the impedance of the speakers, my sixth sense told me that this was the way and will not copy designs of woofer in parallel and in series , but I did listening tests and everything was a disaster.
My speaker is designed and perhaps a coincidence , to dominate any genre of music, the sound is clean with detail and transparency and seductive.
About the speakers to use in this project for a DIY ; I believe that caution should be ... especially all the drivers choose to have the same sensitivity and and avoid L pad,this may bring a bad end sound ,ideally the drivers run freely.
Today I made new measurements with the newest version of Room EQ Wizard.
You can see that between 350 hz to 60 hz,..... I must reinforce that area with a driver for more sensitivity, this.....
http://www.scan-speak.dk/datasheet/pdf/22w-8534g00.pdf
My current crossover
Ideal response curve
Greetings and thanks for paying attention to my work, but you have twice the merit to do a review excellent. 🙂
Where did you get the grill
My Amati !!
An adventure to built the Sonus Faber Diy .
http://www.hifi-notes.com/sonusfabe...abrikage-nl.htm
:: SONUS FABER ::
Here are some DIY photos of my creation at my apartment in Florida.
materials.
Oak wood
MDF
48" H x 12"-1/4 W (at front) x 21" D .
Where did you get the grill?
Oak Round Moulding - Lowe's
Shop oak round moulding at Lowes.com
Grill Cloth - Parts-Express
Speaker Grill Cloth Fabric Burgundy/Beige Stripe Yard 36"
Glue Gun - PRO9500A Adjustable Temperature Glue Gun (Part# PRO9500A735 COMBO)
http://ptscoshop.com/surebonder_9500a_glue_gun.htm
wow... Fantastic... nice job... charming
you can use Speaker Fabric | Critesspeakers.com Fabric Grill
which country are you?
I'm very interested in the amarti... I wish you could build one pair for me
Thank you ! ;I was born in Cuba but I live in the United States.
I FEEL CUBA.mov - YouTube
Fantastic work, Julio! Very inspirational. In fact, you've inspired me to build something similar. Would you please explain the method you used to construct the outer curved shell of the cabinet? What types of wood and what thicknesses did you use?
Much appreciated,
John
Much appreciated,
John
Much appreciated,
John
There are many techniques for bending wood or plywood,in my case I used plywood with termination oak, the plywood was immersed in water for 30 minutes and then forced into the structure made, depending on the environmental humidity takes between 2 to 3 days to dry........and then to glue. 🙂
I used two layers of plywood 1 / 4 inch, total thickness 1 / 2 inch per side,each speaker weighs about 120 pounds.
Example of some techniques......
Plywood Bending
plywood bending - YouTube
Wood Bending
update........
I have changed the first woofer (cutting at 350 Hz) to other most sensitive ......
......obtaining that the third and fourth octave are evenly than the other linearly.
Plywood Bending
Wood Bending
Thanks!
Check out these Sonus Faber Amati Homage Clones.
There at the bottom of the page and in white.
They look amazing.
http://www.htguide.com/forum/showthread.php?7515-Club-Sonus-Faber
They look amazing.
Here's the right link to the Sonus Faber Amati Homage Clones. Its at the bottom of the page.
http://www.htguide.com/forum/showthread.php?7515-Club-Sonus-Faber/page3
It looks like the Amati Homage clones are using 2 Scanspeak 8 inch woofers, Skaaning midbase and Scanspeak Ring Radiator tweeter.
Disappointing... You put the time and effort into the cabinet only to let it down with the drivers. As an owner of a genuine pair of Cremonas I can tell you that your cabinet work and crossover is on par with the Cremonas, but below that of the Amati's. fantastic effort but please change the drivers to something more worthy.
The final lacquor finish should be improved a little bit, for the actual Sonus Faber like shiny finish. This is such a nice work. Just a bit of touch would make this perfect.
Thanks for sharing.
Doug
Thanks for sharing.
Doug
Can the drivers used by Sonus Faber be purchased off the shelf?
Nearly... You can buy the same make and model but the SF drivers are mildly tweaked for SF.
- Sonus faber amati !! Diy
