...all amplifiers of adequate quality sound the same when used within their capabilities
Again, that's a qualified statement (and the way it's worded, rather tautological). It is NOT "all amps sound the same."
This seems to be a difficult concept.![]()
We know what he means, surely.
The statement has to be qualified in advance to stop people from simply saying "Well obviously this Sanyo music centre doesn't sound the same as this Krell." How could Peter Walker have worded it to get any closer to a real, practical "All amps sound the same"?
Not difficult, possibly too easy.
I think most don't like the idea of 'good enough'. That is, It does it's job and doesn't add anything noticable. Then it's an amplifier. If it does add something to the sound, like a tube amp that adds "warmth" (whatever that means?), it's not just an amp, it's an amp+effect box.
The list of amps that meets this criteria -
"high input impedance, low output impedance, flat response, low distortion, and low noise"
would include just about every inexpensive receiver or integrated, basic amp made and sold in big electronics stores from maybe 1975 on to present day.
So if someone is a purveyor of this philosophy that states all amps that meet these qualifications, when used within limits, all sound the same...
They are very close to, in essence, saying "all amps sound the same". If you like numbers, it would probably mean 99.99% of the amplifiers made and sold for the last 35 years meet the above criteria. This logic would extend to 99.99% of all amps sound the same.
...why am I even typing this? it is so obviously silly.
If that were not the case, all you'd ever need would be a pair of B&K measurement mics. Record anything and everything with those.
I've used B&Ks for live recording- I really don't think they're particularly special or uncolored. They're very good, but no "better" than many other condensers.
This is why I prefer to hear classical music in an anechoic chamber. I don't won't any of those hall colorations or acoustics getting between me and the musicians. Keep it pure!Admit it, Stuart: you like boring, clinical, uninvolving sound so you are forced to rely on the musicians to provide your enjoyment.
BF, the problems come elsewhere- for example the "no clipping" requirement. Stability into loads. Power supply sag and modulation. Source impedance over the audible range. Current capability in situations where speakers demand it. That said, these are not hard requirements to fulfill.
Peter Walker didn't write the Wikipedia entry.
In 1975 I suspect that crossover distortion was still a problem in some commercial designs
Then it was surely the last year that saw this distorsion being
still alive , in very few designs , though....
I'm actually surprised how simplistically silly it is... i'm taken aback.
We know how good an amp needs to be to be acceptable for specific purposes, boom box amp vs pro-sound amp. I suppose that the search for the "better" amp is really the search for the amp that incorporates the effects that evoke an emotional response, for example 'warm' sound could be relaxing. This could be found by letting a test group have some effects equipment and see what they come up with. Then quantify that sound profile and integrate into an amp.
Better to suspend the musicians in free space. Saves money on foam wedges.
In 1975 I suspect that crossover distortion was still a problem in some commercial designs, so the requirement of "low distortion" might not have been satisfied.
They were measured on full power, so were satisfied. Crossover distortions resulted in higher S/N level.
Peter Walker didn't write the Wikipedia entry.![]()
Lucky he is. I tried to contribute to the "Tube Sound" Wiki page, to discover that my contribution was called barbarism and deleted.
Tomorrow I'll have a look in my copy of that huge book about Quad by Ken Kessler to see if there's a more definitive reference for you.
That's only one dimension, and an overused one, at that. There are many other qualities that are sought after and heard in amp - real or imagined. The old "effects box" and "tube warmth" clichés are pretty tired. Not to say they don't exist, but they are far from a complete picture.I suppose that the search for the "better" amp is really the search for the amp that incorporates the effects that evoke an emotional response, for example 'warm' sound could be relaxing.
Bill Whitlock has written about a test he came up with, injecting a 60Hz current between an input's ground connection and the chassis, and measuring how much of it appears on the output. This was specifically to measure ability to reject ground loop currents, but no doubt the idea can be expanded to RF susceptibility as well.Yeah I liked your ideas. We could do with some way to measure sensitivity to interference on input grounds and on speaker and power leads. Not sure how to quantify those effects but I reckon they're important. Perhaps the CE tests for fast transient immunity would be a start, but they need to be conducted while playing a real signal, preferably music, and the input and outputs diff'd.
Too true. A few nights ago, I had a long conversation with a recording engineer about my mike preamp. He just couldn't "get" the notion of a box of gain that simply amplified without coloring or why in the world someone would want to build such a thing.
I've seen it all (or so it seems, and heard a lot) on rec.audio.pro. Market it as having the "SY signature sound." If someone finds the sound too boring or whatever, say it also works well with a transformer on the input and/or output.Of course not, that's not how recordings (or even live) work. Mics and preamps are chosen for their "sound". They are tools to achieve and end, an artistic end. If that were not the case, all you'd ever need would be a pair of B&K measurement mics. Record anything and everything with those.
Photographers use filters, odd exposures, Photoshop and printing tweaks to achieve the look they want. Straight forward photos are often pretty boring.
And something that most people know, different pre input impedances change the sound of dynamic micrphones. Add an input impedance switch and label it "tone" or "coloration select."
I take that back. Make two models, one with higher input impedance than the other. Sell them as two different "flavors."
Absolutely right. I can argue here among DIYers, but I stopped arguing on gearslutz.com about this matter: if people want to believe that my amps and microphones "add warmth and transparency", so mote it be.
'Adding transparency' - that one I like. Perhaps we could though say it adds 'negative opacity'?![]()
Does it matter?
When people getting rid of some nasty distortions as if hear some nice coloration added, it is their right to believe. They need to call the sound somehow.
Wave do you have a better copy than MP3 ...?
Why? I expected Scott to ask, it is a song about Boston.
Sounds more like an spring reverb ......![]()
Don't you like it? They did.
- Member Areas
- The Lounge
- Sound Quality Vs. Measurements
