Hi all, I'm putting my Mouser order together for the Speaker Protector and Softstart boards and I could use some recommendations. Can anyone point me to Mouser items for the Euroblock, Faston terminals, standoffs, and LEDs?
Also, how about a set of gold plated speaker binding posts?
Thanks!
Thanks!
Would this work for the terminal block?
1729128 Phoenix Contact | Mouser
Also, here are some faston terminals:
http://www.mouser.com/Connectors/Terminals/_/N-5g5u?P=1z0z63v&Keyword=faston+terminal&FS=True
That terminal block looks ok. As for the faston terminal this one should work ok 63949-1 TE Connectivity / AMP | Mouser
Thanks! Any recommendations for LEDs?
My problem is, when I search for LED circuit board indicators, I get 7,662 matches on Mouser. If I narrow it to 5mm red, I still get 75.![]()
Here you go...
C566C-RFN-CT0W0BB2 Cree, Inc. | Mouser
So, I desoldered the flip flop section and resoldered it and it's fine now. I'm thinking, maybe I'll change the caps to make the blinking less frequent.
I played with it a little, and noticed that when I plugged to the speaker connection a 9v battery the relays went off.So a question popped in my head. What's the mininum dc that makes the relays go off? I tested with 1,5v but nothing happened.With 3v it was going on/off constantly.
How could we bring the sensitivity down to 1-1,5v?Or is it too low you think?
Glad the blinker is now "blinking"... ;D
It was meant like that to eliminate any false tripping of the relays. If you are worried about DC offsets reaching 1V to 1.5V and you want to deactivate the relay, the two 27K resistors can be reduced to about 15K. Be warned though that I cannot guarantee any false tripping especially when playing loud levels so I suggest that you leave that be.
- The diyAudio Store
- Speaker Turn On Delay and DC Protector Board Set (V2)
