Split wire into 8
I have one power supply (smps3ka400) which can be used to power 8 amplifier boards. There are as standard only 3 connectors 'out' on the board. I thus have to split anyway.
I thought the cleanest way would be to take one out and split this into the 8 amplifier boards. I saw somewhere in a build a board where he put 1 wire in and 8 came out. I need a huge "wago" splitter in fact.
I would like it to be safe off course, clean and safe...
Tanks in advance!
I use power strip connectors.
Instead of one wire splitting out to eight, i would take one wire out of power supply, and lead it to eight inlets, first, then from this to second, from this to third and so on.
Then on the other side of this power strip eight amps connected.
The same for other wire, so three power strips total.
https://www.google.com/search?q=pow...-verizon-sscr&sourceid=chrome-mobile&ie=UTF-8
Ah ok, that's not a bad idea, so bridge all of them at the back and in the front put 1 wire in and 8 out! Good idea! I was looking at "distributor blocks" but those were very bulky.
I only need to split the +, - and gnd, so 3 of those strips should do it. Not sure about safety (I usually never use screw terminals but prefer wago as no hot screw can be touched)
https://www.automation24.be/nl/dist...o94JIPW_p7EwjYLjga8SZfShmaTkSp9IaAsX7EALw_wcB
