Stax SRD-7 Adaptor Upgrade
luckily I have 2 SRD7s. one modded, one stock. so I did some further tests this time with a more detailed side panel and some comparisons.
I don't trust that my instrument (R&S UPD from late 80s) has super accuracy when measuring impedance for non standard speaker Items. it goes up to only 600ohms and is only extremely accurate below 50 ohms and starts to very upwards from that and its sat for ages without service calibration. but it definitely is enough to show acceptable correlation. I did see this in measurements of other devices I did and compared to what can be found online which were quite accurately comparable. and the graph here just seems worlds apart from mine. Don't know what's the explanation for such.
here are the results:
INPUT Z
Modded SRD7 with SR303 headphones (set as REF for comparison on the faded trace and dB deviation scale on right side):
Modded SRD7 without any headphones pugged in:
Stock SRD7 with SR303 headphones:
Registered to share that I modded my SRD-7 MK2. Can confirm the MK2 has two 10Ohm thermistors in parallel for each channel unlike the MK1 with a single 4.7Ohm. I just replaced them with a single 4.7Ohm 5W resistor for each channel and it seems to be working fine. Also interestingly the 27Ohm resistor that the MK1 has is missing on the MK2. I didn't add one, should I?
Also what is the best way to measure bias? If I measure from bias to the chassis I get about 330V instead of 580V. Are the caps in my bias circuit going bad perhaps?
Sorry for the delayed reply, I've been taking a break from audio. If those resistors have magnetic material in the body (most do), I'd bend the leads upward to get them both as far away from the xfmrs as possible.
Yes.
Measure it before the series resistor.
Sorry if this is off topic, but I ditched my adaptor and built a dedicated amplifier. Quite an improvement.
Yeah, direct drive amps are good. I have some DIY amps from years ago and an SRM-1 / Mk-2 but I am still interested in the energizers, and I'm working on a board to upgrade the common stax energizers to provide pro bias. A complete replacement with some refinements over the original circuits.
I have official stax schematics for SRD-5, SRD-6, SRD-7, SRD-7 MkII, and SRD-7 Pro. I have yet to see a schematic for a 6/SB or 7/SB and i would like to accurately understand how they are different so i can incorporate features into my board design.
Pretty sure i saw an expert say that some of the self-bias energizers tapped both transformer outputs for volts and then later 7/sb models added another transformer to further isolate the bias circuit from the output but no details. I also have an SRD-X which seems to also be self-biased with an additional small transformer. I don't recommend the SRD-X because it has a literal 80's era car radio power amp chip in it and the sound signature is very dry.
The 5, 6, and 7 wall powered normal bias energizers all have a crockroft-walton multiplier with two diodes and two capacitors(with various different capacitor sizes and types) following a bidirectional zener that, from my measurements, limits the input voltage to about 86v. Some of them have an 0.01uf cap between the final bias voltage and the transformer center tap - the multiplier caps are usually 0.1uf or 1uf.
That picture clearly shows 3x 0.1uf, what looks like the bidirectional zener, and then 3 rectifiers, and then a much bigger cap.
Apologies for the necro-response. To the best of my understanding, the 27R resistor across the transformer flattens its frequency response a bit and makes it a less reactive load for the amplifier by assuring a maximum impedance of 32-ish ohms for ultrasonic signals.
I would say that it appears to be very optional, may help, won't hurt.
