Stetsom HL1200.4 Power supply Mosfet IRFB448
Good day. I am working with Stetsom HL1200.4. The amp is totally dead without any light. I found out that the 4 power supply Fets are shorted, It has the IRFB448 mosfets in the power supply. This mosfet is hard to source from reliable sources. Did anybody tried for a similar substitiute of this mosfet that is available in reliable sources. Please share if you had luck replacing it. Thank you.
