Sub 4 ohm drivers
That said, as you probably know, most speakers measure considerably less DCR than their rated impedance. If you measure vintage speakers the DCR is generally much closer to nominally stated impedance. It seems there has been an impedance inflation in the last 30 or so years.
Like your sense of humour) yes, that's you can call impedance inflation. I had measured a Sony made woofer rated 16 ohms eighteen years back at 14.6 ohms. It now shows 12 ohms!
Probably the ferrite core material degradation (depreciation?) has something to do with this.
