hi zivkof
i am out of the county for the next couple of weeks.
so no time to sim something.
bild quality seems to be ok.
another sugestion is b&c 18tbw100 .(x-var 14mm)
P is for Parabolic, you have constant width and should probably sim it as parabolic instead of conic.
Thanks NEO Dan, yes I know it is much easier to construct box with 90 degree inside pannels. Inside the box I have 5 five volumes, Volume1<Volume2<Volume3<Volume4<Volume5, so how I can change sim from conic to parabolic?
Tap the P key in the length (L12-L45) fields where you have conic now.
Thanks NEO Dan, have just done that, but it is small small deviations between Par, Con and Exp. The most closer to the real volume is under Exp.
hi thereHi epa, it looks quite good, I have done some Google SketchUp8 plans.
great simple and effective design.
time to make sawdust
![smash :smash: :smash:](https://files.diyaudio.com/forums/images/smilies/smash.gif)
I would re-name that cabinet, as to not confuse it with the Danley Sound Labs TH-118...
yes thanks for proposal, I will do that it should to be called: 19 Hz Tapped Horn as 1/4 horn path is 15 foot long
hi there
time to make sawdust![]()
Hi epa,
sawdust is on the way, it will be finished in 2-3 weeks time with painting.
gr8
pics or ir never happened![]()
I know there will be a lot of pics, BB ply is already cut, just ordered Tuff Cab black paint.
- Subwoofers
- Tapped Horn TH-121 build
