Oh, I didn't think to split the pressing.I'll ask, but it seems unlikely on their package deal that they would split the pressing. [...]
Pressing can be done as a whole in Canada, the Canadian arm could send a batch of LP's to their sister company in Czech Republich, and from there to the European customers....
Of course, it's just that those records also cost some 30-50 Euros....Why are we trying to test the limits of tracking for cartridges anyway? There are test records out there that do that. [...]
If it can be done without to much drawbacks, why not.
I would definitely grab a couple for myself and might potentially be able to persuade others to give me money for a few more.
I self financed my last group buy and collected the funds just before I shipped out the boards and transformers, this is the cheapest and least complicated way to go, but depends very heavily on everyone trusting each other, and a willingness on the part of the fellow fronting the money to risk his funds.. (You can also collect in advance which is what I recommend)
Should obviously (IMO lol) all be pressed in one place, we want a consistent product flaws and all. Part of the usefulness may be knowing that everyone has as close to an identical product as is possible, split it between two pressing plants and costs go up and consistency is lost.
I put the price at $15, as a safety margin.
I'm in for two.
Hi sottomano,
Personally, I don't need any track that could be easily damaged for no useful information. I honestly don't see any use in testing that parameter. The information in the datasheet for that cartridge should be enough. You're not going to run into the limits of your cartridge to track. If you have a tracking problem, it will show up as distortion on a normal track at high (normal) levels, and that would be a concern.
I could go for 5 at $65. I have a friend who would gladly take one off my hands.
-Chris
-Chris
and heavy vinyl.
180g vinyl isn't necessarily technically better. I believe I have at least one paper about this. I'll look it up and post it.
Don't forget flatness, the STR series on ordinary vinyl has a few badly warped examples.
Yes that is true and more so for 200 - 220gm vinyl. It just looks better. I think 140gm is considered a bit of a sweet spot, not as floppy as the lighter 120gm pressings. I believe part of the problem with the heavier biscuits is that the additional mass makes it more difficult to achieve optimum temperature and pressure during pressing.
With some geometries it seems to be. (The shibata, blah, blah, blah..lol) I try to compromise by setting VTA using a record in the middle of the range of the ones I have.
I am not convinced there is a universally correct VTA setting even for records of the same thickness, although the range is probably pretty narrow.
I plan to add a VTAF on the Schick in the not too distant future which allows on the fly adjustment.
The Article had this one interesting statement:
"..., aber Kai Seemann hat andere Erfahrungen gemacht: „1993 habe ich bei Pallas verschiedene Alben jeweils als 140-, 150- und 180-Gramm-Version pressen lassen: Innerhalb der Gewichtsklassen waren die Unterschiede in puncto Verwellung viel größer als zwischen den Klassen"."
"but Kai Seemann made different experiences: "1993 I had different albums pressed at Pallas each in a 140-, 150- and 180-gram-version: within the weight classes the differences regarding warping were much bigger than between the classes."
Kai Seeman is the boss of Speaker's Corner Records, an audiophile label, Pallas is a highly regarded German pressing plant.
This is qoted from Stereo magazine issue 1/2017.
I'm planning the same upgrade for my SME 309 (and I know you are not fond of that generation). It's slightly kludgy in that you have to loosen the clamp and to go down you still have to push, but at least its calibrated*. The audiomods setup is nicer in that respect. Of course ideal would be remote control from the listening position. Air tangent used to do it.
*It's also a bit pricey but does give me a damping trough. Seen as the AT-150 is going on there soon I'll probably need that.
Oh and another vote for 140g
Yes, please do! Getting direct contact with an engineer is very valuable. Let's see what someone else can do for us. Thanks.I have contacts to a mastering facility in Berlin. They offer half speed mastering and their engineer has experience starting at the Deutsche Grammophone. If there is interest I could talk to him about the project to get a master for the European pressing done.
- Analogue Source
- Test LP group buy
