Concerning speaker room interaction i regard
distributed mode loudspeakers highly interesting.
The following paper is in german language unfortunately,
but on page 14 ff there are some diagrams which show
the influence of reflection in comparison to conventional
speakers.
http://www.wvier.de/texte/NXT_Tonmeistertagung.pdf
As i am experimenting with that technology, a can underline
from personal experience, that DML behave extraordinarily
benign concerning deficient acoustics in small rooms.
As the common living room cannot be modified into a perfect
listening room, a more benign speaker techology is the key
point in my view.
Kind Regards
speakers.
point in my view.
Kind Regards
in fact DMLs are similar to cone-driver-based omni speakers in one feature that is crucial from the the perspective of room-speaker interface - they have very broad dispersion and thus maximum interaction with the room
Here are some polar plots and of axis measurements.
http://www.soundcontrol.tudelft.nl/Personnel/Rinus Boone_files/RB_AES2000.pdf
I cannot agree in so far, as DML directivity can be shaped by
the housing similar as with conventional speakers too.
The well known monopole-kardioid-dipol shaping of the
dispersion is possible similar as with conventional speakers.
But the CHANGE in directivity due to driver dimensions related
to wavelength does not occur as pronounced.
Have you seen the plots in the first paper ?
The diffuse radiation especially towards larger off axis angles
minimizes comb filtering to an extent, which cannot be achieved
with a piston acting speaker.
When listening to DML, the speaker "disappears" and cannot
be localized as sharp like conventional speakers.
For a conventional speaker it takes many conditions to be met
before disappearing itself: Listening room, recording everything has to
fit before music is released from the speakers.
Using a DML this is more something like the "normal mode of operation".
Kind Regards
Kind Regards
Whether reflections are audible or not is a function of timing and intensity. The earlier the reflection the more intense it has to be to be heard, the further on after the initial event and it can be lower in db and still distinguished.
I've found this to be true within the envelope that people seem to agree matters the most 1ms-6ms. It's a bit tricky though because above or below that envelope it seems to change. And really the whole thing is kind of counter intuitive to me. I would have thought that the earlier reflections would need to be softer to be innocuous. But you can really push a reflection way up in volume around the 1-2ms region compared to the 5-7ms region. The later the reflection in that envelope it seems the softer it will need to be to blend in with the direct sound. But if you make the reflection really short it doesn't seem like an echo but just sort of a 3-D effect that is hard to even notice unless you can turn it off.
it is not that difficult, all unorthodox setups described in this thread - CFS, SLS and Carlsson - excel at disapearing act
as to DMLs I am no expert, I rely on what I have found:
http://dspace.upv.es/xmlui/bitstrea...d=27DA9794EFADFFAF1B1FB4471E010D0D?sequence=6
2.2. Distributed Mode Loudspeakers
2.2.2 Radiation Properties
The polar response of a DML is again dependent on whether it is radiating below or above the coincide frequency, as stated in several studies
Below coincidence frequency
The polar pattern is an interference pattern for an odd and even mode strip radiator, which is orthogonal and thus the radiation pattern will swap from one to another. When many modes are excited, this summation of patterns gives a quasi-omnidirectional response but in reality, strong frequency variations are occurring at the listening point.
Above coincidence frequency
For this frequency band, the sound radiation is highly directive due to the occurring coincidence. The pattern is a combination of single lobes from forward and backward waves for each excited mode. As frequency increases, such lobes become narrower and progressively move to the normal direction. As many modes are excited in a DML, the overall pattern is again a superposition of these lobes and would look omnidirectional. This would give the impression of increasing dispersion with frequency and thus diffuseness, as the radiation pat tern becomes increasingly lobulated.
2.2.5 Room Interaction and Sound Localization
The reaction of diffuse sources, such as DMLs, to room boundaries is less severe than traditional piston loudspeakers.
DML sources produce room reflections that are less correlated to the direct sound than those radiated from piston sources and thus, constructive and destructive interference of sound is minimized.
best,
graaf
What's unorthodox about Carlsson speakers? I read the "Ortho- Acoustic Loudspeaker" paper (http://www.carlssonplanet.com/downloads/uploads/carlsson_ortho.pdf). The OA5x tries to mimic a flush mounted speaker and comes with some built-in absorber panels to kill first reflections.
Well, Blauert wrote about that some 40 years ago...
Jens Blauert "Spatial Hearing"
I'm sure lots of people have noticed this. I'm not fooling myself into thinking that what I am experimenting with is cutting edge or anything. It's not exactly new but maybe the specifics and just putting all the pieces together in a way that actually works that might be somewhat new.
o yeah, 40 years ago...
and yet...
...The influence of reflections is not fully understood. Everybody is guessing and declares his own experience the truth.
Toole himself asks the right questions in his AES paper "Loudspeakers and Rooms for Sound Reproduction—A Scientific Review". There is strong evidence that number, spectrum, angle, level and delay of single reflections are the key. We just don't know yet what the important properties are and how to measure them.
"Blauert wrote" yet we still do not know
yet somehow we know that "that cannot work, this is nonsense" etc. etc.
? You should read less between the lines...
I think that is basically what i said. It describes a highly
useful property of that kind of speakers with respect to minimize
loudspeaker room interaction.
Realistic (though exemplaric) data concerning directivity you can
find e.g. in Fig. 5 of the second paper.
Polar plots of DML look very different according to size, panel material
and mounting conditions.
To think about: The strong desire for directivity in piston acting
Loudspeakers when minimizing room interaction comes from
strong interference of conventional (non diffuse) loudspeakers
with room boundaries ...
Although you can shape DML directional too, this is not neccessary to
the extent you have to do it when minimizing boundary interference
for conventional speakers.
This in turn gives a very wide listening area of nearly constant
quality. It is simply "amazing" ...
Kind Regards
I'm sure lots of people have noticed this. I'm not fooling myself into thinking that what I am experimenting with is cutting edge or anything. It's not exactly new but maybe the specifics and just putting all the pieces together in a way that actually works that might be somewhat new.![]()
I agree that own experience has always a different value than theoretical
knowledge. Although i know the mentioned book from Jens Blauert
- it is in fact one of my favourites -
i am experimenting sometimes, even though it is not leading edge.
Kind Regards
have You ever anywhere seen anything similar?
there are much simpler ways to "mimic a flush mounted speaker" than making a very short speaker with drivers firing diagonally up to the ceiling
the Carlsson way means also effective handling of early reflections from the side-walls, floor and ceiling, much more than "to mimic a flush mounted speaker"
I've seen a couple of "unorthodox" speakers, yes, but the interesting thing is the design principle of a speaker. The Carlson looks not "unorthodox" to me.
there are much simpler ways to "mimic a flush mounted speaker" then making a short speaker with drivers firing diagonally up to the ceiling
the Carlsson way means also effective handling of early reflections from the side-walls, floor and ceiling, much more than "to mimic a flush mounted speaker"![]()
Did you read the Carlson paper? It exactly describes the same principles that led to flush mounting or constant (high) directivity concepts.
ok, great!
What kind of a question is this?
Let me answer accordingly with similar questions:
Did you read my first post in this thread? Did You read Harold Beveridge's paper on room-speaker interface? Or Moulton's? Or Linkwitz's presentations?
Yes. Do you realize that these names and their concepts stand for very different sound fields?
Now tell me what is wrong with my proposition? What calculation is wrong? What asumptions are mistaken?
Surely there are VERs <1 ms from the adjacent wall but I cannot hear anything bad that could be attributed to them.
I can hear no mucking up of the image, nothing unnatural that "sounds like nonlinear distortion", and certainly no audible unnatural image shift nor widening nor blowing up - which in that case is quite expected because those VERs are coming from the same direction as the first wavefront within just +/- couple of degrees
In the < 2ms. region we found that the VER would actually sound like nonlinear distortion, and are highly dependent on absolute SPL, but also muck up the image. At greater than about 2 ms. the effects transition more to coloration than image. At about 10 ms. the negative effects of reflections begins to go away and by 20 ms. the reflections become positive being perceived as "spaciousness", reverb, etc.
what do You mean by "very different sound fields"?
Yes I realize that in each case there is very different sequence of room reflections, that is for sure BUT question is - how does it translate into audible sensations?
Can we tell from the perspective of audibility which of those "sequences of room reflections" is optimal or at least better than other or at the very least audibly "very different" from other? Can we?
This is the question - how those "very different sound fields" translate into what we hear?
Because each of those "very different sound fields" room reflections differ in direction, timing, intensity and spectral content whether (and to what effect) reflections are audible or not is a function of timing and intensity, and direction and spectral content and so on and so on
perhaps from the psychoacoustical perspective of audiblity and of detrimental effect the differences are not that huge as from the physical perspective of "very different sound fields"?
What do You think?
- The Advantages of Floor Coupled Up-Firing Speakers
