What good does it serve for other readers to describe what only you can perceive in your own unique setting?I haven't said what my preferred dac is, not yet anyway. Maybe more to say after the listening session.
One can speculate till the cows come home but that won't do anyone any good except for marketing literature.However, its possible there could be mechanisms that do not show up fully in this type of test. It would presumably depend on exactly how the modulator is designed.
Regarding the test itself, seems to me it suggests that, say, for a small HF signal riding on a large LF signal, the small signal would be modulated differently by noise depending on relative level of the LF signal at the time
What process revealed that known artifact? Without a clear description, you are just inviting more complaints.Some known artifact that isn't so easy to see on a typical FFT could be a much more plausible explanation.
I guess you missed my joke: the piano used in the recording was actually a Bösendorfer![]()
Thanks... makes me think that all records should be forced to state "NOT A STEINWAY" if that is true (for the Steinway fanatics).
Can you guarantee that the fundamental spectrum component in an FFT as being referenced to 0dB is undistorted?What good does it serve for other readers to describe what only you can perceive in your own unique setting?
Not good enough... nothing to do with audibility...
It's how much of distortion is audible or not.
Can it be guaranteed that, in only the observation of an FFT spectrum, whereupon the fundamental component at 0dB (being mathematically perfect) can itself still be considered a contributor of distortion?Earlier there was some discussion as whether -85dB distortion is audible. Maybe not if its 2nd or 3rd order. What about if its undithered 16-bit truncation distortion?
You misunderstood what the discussion is about.Not good enough... nothing to do with audibility...
In-band IMD is not inherent to NOS. It only seems to be an issue in intellectual contemplation, and which depends on the design of the post D/A circuitry. I’m aware of no logical argument for why NOS is inferior to OS for the purpose of humanly audible music playback, where the ear acts as a biological low-pass reconstruction filter, effectively removing the image bands. As I had observed earlier, the top 5 DACs of the post #1 listening tests ALL featuring NOS, while the remaining two at the bottom feature integrated OS. Which argues that, at worst NOS does no subjective harm, and at best is a significant element to the subjective performance those top ranking DACs. It remains unanswered in the test, to what degree NOS is responsible for the sound among the top tier group. Just to make it clear, I don’t see the problem as OS, in itself. For it is, in mathematical sampling theory, perfect in digital signal reconstruction. Instead, I see the problem as the inadequate practical implementation of the integrated interpolation-filters within a great many monolithic DACs chips. External OS via s/w on PC, for example, can subjectively perform at a level with NOS.Since there are always non-linearities IMD products of ultrasonic components will appear below 20kHz.
No, but the higher the ultrasonic components the higher the IMD products of ultrasonic components.In-band IMD is not inherent to NOS.
Sure, if the lower ultrasonic images of NOS were a problem in the first place. Which, they evidently weren’t in those five NOS DACs which were all subjectively judged as surpassing both of the OS DACs.No, but the higher the ultrasonic components the higher the IMD products of ultrasonic components.
As "relevant" do you mean one that doesn't threaten to "deny thy faith"?Ask a relevant question and the answer shall be forthcoming.
My comments were not related to OP's listening test. Sure you can argue that the IMD products caused by NOS were not a problem for these listeners. Who knows, they may prefer distortions and other non-linearities. Others may feel different.Sure, if the lower ultrasonic images of NOS were a problem in the first place. Which, they evidently weren’t in those five NOS DACs which were all subjectively judged as surpassing both of the OS DACs.
Since you have a difficult time understanding the concept, the following are some examples of relevant questions which I still haven't seen the answer.As "relevant" do you mean one that doesn't threaten to "deny thy faith"?
1)
Relevant question:I recently compared
How was the listening (since it's audio, ultimately one's ears should be involved) comparison carried out?
2)
Relevant question:This applies to both Mark4's claim and yours in stating "Both DACS have distortion levels and sound coloration below audible threshold".
Is my claim an extraordinary one?
What "concept"? No difficulties here. Are you suggesting that answers to your so called "relevant" questions are ones threatening to "deny thy faith"?Since you have a difficult time understanding the concept, the following are some examples of relevant questions which I still haven't seen the answer.
1)
Relevant question:
2)
Relevant question:
The -85 dB we discussed earlier came from a transimpedance amplifier without overall feedback, so chances are it is low-order distortion.Earlier there was some discussion as whether -85dB distortion is audible. Maybe not if its 2nd or 3rd order. What about if its undithered 16-bit truncation distortion?
Regarding undithered quantization, the RMS level of all quantization distortion products together stays at about the same level as the desired signal drops, so it gets worse with respect to the desired signal; -98 dB at 0 dBFS becomes -58 dB at -40 dBFS. It also gets less noise-like with dropping level, that is, the chances of getting a spectrum that doesn't resemble noise at all gets worse (1). It is still so soft that it is questionable if it will be heard under domestic circumstances, but I'd rather avoid it.
(1) It's not a completely fair comparison, but when I was 17, I built a circuit that could store a few seconds of sound in 1 Mbit of DRAM, using an undithered first-order delta modulator to digitize the signal. I use it as a doorbell with programmable sound. It sounds pretty bad at any level, but it clearly gets worse when you record very soft sounds with it.
Regarding the ESS noise floor modulation presentation, and IIRC also a technique used by Bruno Puzeys, a method is used which feeds the dac a digital signal consisting of a DC offset. Noise plots are then taken for multiple DC offsets so as to map out the noise level across the dac's analog output range.
Regarding the test itself, seems to me it suggests that, say, for a small HF signal riding on a large LF signal, the small signal would be modulated differently by noise depending on relative level of the LF signal at the time.
It's a good test. An old trick to hide idle tone issues in sigma-delta modulators is to add a small DC offset that is large enough to shift them well outside the audio band. Play back an opposite DC offset and they shift right back into the audio band.
The chaotic mode of my valve DAC (which is a sigma-delta DAC) has no audible tones, but non-stationary noise that depends on DC offset. For very small DC input signals, you hear the noise varying with a speed that depends on the offset. It is due to a combination of the behaviour of the chaotic modulator and imperfect settling of the DAC. I'm in good company, as Lars Risbo had similar issues with the chaotic sigma-delta DACs of his PhD thesis.
While that is true. What I’m really getting at is, that NOS may be a very key factor in the top five DAC rankings. It certainly jumps out as a common feature across all the favored DACs in this evaluation. There's no way to tell via the result details shown, of course, without further experimentation.My comments were not related to OP's listening test. Sure you can argue that the IMD products caused by NOS were not a problem for these listeners. Who knows, they may prefer distortions and other non-linearities. Others may feel different.
- Digital Line Level
- The battle of the DACs, comparison of sound quality between some DACs
