The construction of a multicell horn
Yes, it would be great to see this pick up again. It's a complex build (or at least repetitive) so maybe a high bar to get started. I do have a few sheets of 2.7mm plywood on hand. Would have to modify the spreadsheet slightly for the difference in thickness.
These horns are NOT a Altec 1505B copy. They are pure exponential with a flare frequency of 183 Hz, the same, or at least what was my and reVintages intentions bacause the throat flare in JBL 2441 and 2445.
The horns are built out of 3 mm Baltich Birch plywood, filled with polyester and the outher sides are covered with polyester and glass fibers.
/Petter
