The Pass Pub: The High-End Off Topic Thread
Official Court Jester
Joined 2003
it really depends what you're looking for
regarding preamps, if no/moderate gain is in case, Iron Pumpkin rulez them all
and - if needing more gain, best scenario - Iron Pumpkin set to 0db, serving as bespoke selector/volume control, followed with any gain stage made properly in separate enclosure
then - amp - what's best for room-speakers-ears combo
what's Aleph 100?
I presume big Aleph, made to have 100W per channel?
Joined 2003
choice of amp - as I said - whatever moves your feet most, in said room with said speakers
I believe Iron Pumpkin is sufficient regarding gain for any of these amps
in case that you want more sugar (even harmonics) with some amp I believe that already mentioned - setting Iron Pumpkin to 0db and using, say, K79 gain stage after, would achieve that
though, take care of setting gain of system (thinking of optional gain stage) that volume control is near max for max SPL you need, so no signal wasted in system
Joined 2003
Reactions: 1 users
