Very good, HF Guy!
that little k is Boltzmann's constant = 1.38 x 10to the power -23 juoles/deg kelvin. Not something I have instant recall of always.
I always remember it as 4nV/ sqrt Hz for a 1K resistor and proportional to sqrt R for scaling.
It helps being a physicist.
volume controler... what for?
could you change volume level in the concert hall?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm not think so.
I never do any volume control in my amplifier. I've set it up during instalation.
I have not problem about different room reaction by different sound precure
and I have clean fron panel as well
http://www.artmaydan.org.ua/hi-end/amp_s.jpg
http://www.artmaydan.org.ua/amp.html
I'm not think so.
Is it just me or does it look far too complicated for what it needs to do? It's not too diufficult to make an attenuator that has 2^N steps (N being the number of relay contacts), and has any dB per step value you want, using 2*N + 1 resistors, that also has constant output and input resistance regardless of the setting, and can be driven by a binary combination to address the attenuation needed, dirtectly?
OK, let's revive this post...
Can someone (ilimzn perhaps) please guide me to a circuit for this " 2^N steps (N being the number of relay contacts), and has any dB per step value you want, using 2*N + 1 resistors, that also has constant output and input resistance regardless of the setting, and can be driven by a binary combination " type of volume control / attenuator.
I would appreciate the circuit for the control system as well as the attenuator.
Many thanks.
ilimzn said:Is it just me or does it look far too complicated for what it needs to do? It's not too diufficult to make an attenuator that has 2^N steps (N being the number of relay contacts), and has any dB per step value you want, using 2*N + 1 resistors, that also has constant output and input resistance regardless of the setting, and can be driven by a binary combination to address the attenuation needed, dirtectly?
Many thanks.
- The remote control paratactic volume control
