thanks Marcel, if i read you correctly:
- you will need an insane amount of jitter for audio noise floor to be affected
- the jitter induced audio noise is not likely be measurable with Andrea's clock or those audio grade Crysteks, using a soundcard
right?
No, not quite.
Phase noise and jitter are different metrics for the same variations of the clock, but what effect those variations have depends a lot on whether they are fast or slow variations. Phase noise is specified as a function of offset frequency while jitter is a number that doesn't show clearly whether the variations are fast or slow. Hence my preference for phase noise.
Whether the audio noise floor is affected much by far-off phase noise/the phase noise floor depends a lot on the type of DAC. Multibit DACs with no noise shaping are not particularly sensitive to it, while single-bit sigma-delta modulators with a single return-to-zero DAC are quite sensitive. Other types, such as multibit sigma-delta DACs or sigma-delta modulators with a switched capacitor DAC or a big FIRDAC, are somewhere in between.
Close-in phase noise produces the same skirts around the spectral peaks of the desired signal no matter what type of DAC you use, but those skirts are so small they will be very hard to measure (see post #4218). They are also so small I wouldn't worry about them. Still, they do get smaller when the close-in phase noise is reduced, so if you want to be perfectionistic about it or simply don't agree with me, use Andrea's clock generators.
Are you AudioPolice representative? We are able to make our own minds and there is no need to "defend" us. I see no laws broken, as nobody forces no one to buy anything.I'm afraid it is not you and your DIY partner(s) wasting time and money.
Its diy afterall and nobody expects any warranties and im sure understand the risks.
Im just not getting your efforts..
But it is not your money either. At the very worst one is paying for a device that vastly overperforms. For a bit of perspective consider the Tice Clock.
Hello Andrea,
Regarding the clocks we are constantly talking about noise that most people cannot even measure so if spending 100 Euro on lead to be moulded just gives a tiny difference it would be a good investment.
Because my aluminium boxes are a bit bigger it wont be difficult to mould some " elements " to be glued on the inside.
Because of the position of the connectors and because there is no space to position them vertically i cannot completely surround them with lead shot.
I have to make a real dimension " box " to see what will be possible in real life.
Greetings,Eduard
Hi Eduard,
my philosophical approach is very simple: I could take an uncertain path that could give me advantages or not, will I take it?
Definitely yes, no doubt, even if the benefit will be very small.
This is my own opinion, nothing more.
Andrea
Hello Andrea,
A few more post and you are back at square one defending why you decided to do things the way you have done that.
Vibrations are not much of a problem.
Maybe because you are not selling anything that solves this problem.
Wlowes has done more than the rest of us and he claims it is worth the investment.
Dry sand is cheap and easy.
Of course after the 6 boxes are placed into a bigger box and kind of fixed by a few centimeters of dry sand and/or lead shot it will rather easy to cover the boxes completely with dry sand..
6 boxes in one bigger box will be more effective than each box in its own " vibration absorption unit" Being in one box will reduce vibrations to a greater extent and when there is a vibration all 6 boxes will be exposed in the same way which will be a good thing.
Greetings,Eduard
Greetings,Eduard
Sure, don't forget to add a pair of Wavac mono block power amplifiers in your systems: https://www.wavac-audio.jp/pics/SH-833.jpg Will definitely improve your audio experience, by adding a new dimension to the soundstage.
No, it is not about close-in phase noise...
I think you missed the point. *This* thread and the value proposition from the merchandiser is about close-in phase noise - all the way from post #1. It has been so a long time before you entered it.
Hello Andrea,
Greetings,Eduard
Hi Eduard,
that's not quite the case.
We have chosen a way to shield and isolate the oscillators from the vibrations and we have followed this way.
Finally we have measured the difference and we were satisfied with the result.
There would be several other ways to dampen the oscillators and shield them, but this would involve a lot of time to build and measure different solutions.
It's really difficult for us because our free time is very little and we still have several designs to be completed.
Please, keep in mind that from Monday to Friday (sometimes Saturday too) we have our real job, the job which pays the bill.
And moreover the designs we are currently developing are very complex.
The hardware and the firmware of the FIFO Lite are almost ready, but we have to test it with several DACs, which will involve long time.
I still have to develop the Windows software to manage the settings of the FIFO Lite, it will take several days, maybe weeks.
So I believe everyone could make their experiments and drawn their conclusions, just like Walter and the other members who have shared their way to shield and isolate the oscillators from the vibrations.
Andrea
thanks for sharing this piece of real knowledge.No, not quite.
i am so skeptical because if phase noise does affect audio noise to some good extent, it should have been well specified in the DACs datasheets, but so far none i am aware of.
i will keep this in mind and check this out in practice against theory sometime.
and yes, i think like many others here, i am a perfectionist in the quest for best possible sound and loved to push things to its limit, so thats why i am in.
sometimes something not measurable does not mean its not audible, and sometimes you just cant really be sure if something will work or not until you actually tried it.
this is part of the hobby, and i wouldnt mind to try something even better than Andrea's, if any.
Subjective auditioning isn't solid experience. Why? Because bias and level mismatch haven't been controlled.we all have solid experience on how jitter impact the SQ, well before joining this group buy.
Fact is they don't. Phillips laid out TDA1541a datasheet and offered reference design. 1000's of CDP were then sold by dozens of consumer audio mfg all with same basic design. Most all with mediocre performance.i am so skeptical because if phase noise does affect audio noise to some good extent, it should have been well specified in the DACs datasheets, but so far none i am aware of.
Pedja Rogic, Thotsten Loesch, Lesha all found better ways to implement it. John ecdesigns has 100's of pages of research on diyaudio radically improving the implementation and (percieved) sound pleasure.
Consumer audio is full of same lazy designers dashing to a target cost and release date.
Their faith is being questioned from their point of view (I don't care what they believe), and they react poorly. You should all be interested in the truth. That is all I am looking for.
Not really much point in having faith if you need proof.
Perhaps it wasn't for you. There are many "silent" readers of this forum who are looking for helpful info on getting the most of their hard earned money, like I was.Are you AudioPolice representative? We are able to make our own minds and there is no need to "defend" us. I see no laws broken, as nobody forces no one to buy anything.
You need to brush your understanding of "research". The DIYAudio forum is not striking me as a "research" forum. Neither does ASR, FWIW.
Hi Mark,
Trying to make this easily understood by the masses. I had earlier been specific and said what you did.
Either way, Andrea needs to answer his own questions. I can't believe he undertook such a development without knowing anything about the problem as he saw it.
It is entirely possible that if you have good equipment, Andrea's efforts are a solution looking for a problem.
-Chris
-Chris
Sorry but our free time is very limited, so we have to spend our free time developing the current projects.
I have already explain the way we would measure at the output of the DAC if will ever find the time.
Please, see post #4234
The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
No chance in the next months, sorry.
Hi Andrea,
I'm not explaining anything. You're the one who claimed improvements. You have not convinced me (not that you have to) or anyone else that you understand what you were trying to do. You don't have any metrics on the performance of the systems you are encouraging people to hack into at all. With that in mind, I see you as a dangerous influence for DIYers who wish to improve their systems. I think you should be responsible in your approach and figure these things out.
For your future ventures, please attempt to understand what you are improving and the impact of changes you are recommending. This is both for your own good, and the benefit of anyone who emulates what you had done. Your free time is far more wisely spent when you have defined the problem you are solving and other basic questions.
For systems where the clock is a problem, there are likely other more dominant problems with the design. Your clock improvement likely does not result in any real sonic gain, but when people make changes they will tend to hear a positive difference. That is how the expensive cable industry operates for example.
Good luck to you, but you do owe it to people who do business with you to have relevant information as to how what you do is improving anything. Yes, you are in a kind of business as soon as money is exchanged for goods or information.
No more rocks to hide under it seems.
-Chris
-Chris
Hi Andrea,
No, it doesn't. That isn't even the question.
Please define the state of the average equipment, the source material and better equipment. Then please indicate how much of an improvement you expect to make. Hearsay "evidence" is useless, just what are your findings Andrea? What is the theoretical maximum performance of the system considering the original encoding equipment?
These are basic questions. You had to know what you were trying to improve. You have to know if you did succeed by some other means than "gee, I like this better".
Just answer these basic questions Andrea.
What is theoretical maximum performance of system considering transducer distortion? it often swamps even the most poorly measuring amps, dacs etc.
Are you saying you cant differentiate between any different amps and/or dacs from listening?
Surely not, so can you explain this?
Hi lasercut,
No, it doesn't.
Please learn something before commenting.
No, it doesn't.
Sure I can sometimes, different factors at play. We are talking about a clock. One thing I do is improve DAC and other audio equipment. I'm rather well versed in audio improvements.Are you saying you cant differentiate between any different amps and/or dacs from listening?
- Digital Line Level
- The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
