wlowes
1 x 5.6448 MHz SC-cut
1 x TWTMC-DRIXO-SF
1 x TWTMC-DRIXO-XFMR 5-12 MHz
1 x TWTMC-STS-DX
-G600:
2 x TWTMC-DRIXO New Driscoll semi-finished
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
2 x TWTMC-DRIXO semi-finished
4 x TWTMC-DBM-F semi-finished
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
2 x transformer kit for Driscoll 5 to 12
4 x transfomer kit for freq doublers
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
4 x TWTMC-DBM semi-finished
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-pp bare board
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
1 x TWTMC-DRIXO-XFMR 22-24 MHz
1 x TWTMC-DRIXO-F 5.6448 MHz
1 x TWTMC-DBM-F 5.6448 MHz to 11.2896 MHz
1 x TWTMC-DBM-F 11.2896 MHz to 22.5792 MHz
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DRIXO-XFMR 5-12 MHz
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
2 x 5.6448 MHz SC-cut
2 x 6.1440 MHz SC-cut
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
4 x TWTMC-DRIXO-XFMR 5-12 MHz
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
1 x 22.5792 MHz SC-cut
1 x 24.5760 MHz SC-cut
1 x TWTMC-DRIXO-F 22.5792 MHz
1 x TWTMC-DRIXO-F 24.576 MHz
2 x TWTMC-STS-SX
-markw4
1 x 11.2896 MHz SC-cut
1 x 12.2880 MHz SC-cut
2 x 22.5792 MHz SC-cut
2 x 24.5760 MHz SC-cut
Plus some other stuff
-bisesik
2 x 11.2896 MHz SC-cut
2 x TWTMC-DRIXO-F 11.2896 MHz
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x 6.1440 MHz SC-cut
1 x TWTMC-DRIXO-F 6.144 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
1 x TWTMC-DBM-F 6.144 MHz to 12.288 MHz
1 x TWTMC-DBM-F 12.288 MHz to 24.576 MHz
4 x TWTMC-STS-SX
wyan
1 x 6mHz AT-cut
Any one also interested in 6mHz AT-cut? I am in for one and hopefully the MPQ can be reached.
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
wyan
1 x 6mHz AT-cut
I added another document (part VII) that explains how to connect oscillators, frequency doublers and sine to square converters to Ian's FifoPi.
There are 2 options to feed the FifoPi with 22.5792 and 24.576 MHz.
The first is:
- TWTMC-DRIXO 22.5792 MHz
- TWTMC-DRIXO 24.576 MHz
- TWTMC-STS-SX
- TWTMC-STS-DX
- TWRPS-UGL
The second is:
- TWTMC-DRIXO 5.6448 MHz
- TWTMC-DBM 5.6448 Mhz to 11.2896 MHz
- TWTMC-DBM 11.2896 Mhz to 22.5792 MHz
- TWTMC-DRIXO 6.144 MHz
- TWTMC-DBM 6.144 Mhz to 12.288 MHz
- TWTMC-DBM 12.288 Mhz to 24.576 MHz
- TWTMC-STS-SX
- TWTMC-STS-DX
- 2 x TWRPS-UGL
Thank you as much clearer!
1. What max music sample rate will this support?
2. In your view which one is the best solution?
Thanks!
I'm not sure because I don't own the FifoPi, but from the manual it looks like that with 22/24 MHz master clock it supports 176/192 kHz and DSD526.
Maybe someone expert in Ian's devices can confirm that.
The best solution in term of phase noise is the second but it's more expensive than the first.
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
1 x TWTMC-DRIXO-F 11.2896 MHz
1 x TWTMC-DRIXO-F 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
wyan
1 x 6mHz AT-cut
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
wyan
1 x 6mHz AT-cut
-wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x 22.5792 MHz SC-cut
1x 24.5760 MHz SC-cut
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
2x TWTMC-DRIXO-XFMR 5-12 MHz
2x TWTMC-DRIXO-XFMR 22-24 MHz
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
cable type
I am thinking of using RG174 cable instead of the RG400 as this is much more flexible and usable.
The impedance is higher but I assume this will not impose a problem with the lengths we will be using in audio. I will not need more than 50cm of length.
Or is there a reason to go for the RG400 type that I have missed?
RG178 - Knowledge about coaxial cablesKnowledge about coaxial cables
The angled SMA connector is also more handy than the straight version.
-wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
Supersurfer
I recommend the LMR 195
LMR195 - Knowledge about coaxial cablesKnowledge about coaxial cables
Coaxial Cable Specifications Cables Chart - RF Cafe
any one also interested in 6mHz AT-cut? I am in for one and hopefully the MPQ can be reached.
I will also order AT 6 MHz, I will spread some info on the group buy at the computeraudiophile forum too..
Yes, I ship from Italy (UE).
No custom, but I have to add 22% VAT for EU customers without a valid EU VAT Id.
22% VAT geee, live within the EU (Canaries) and pay local 9% or no VAT for SW/electronics..
a pitta ..
Hp
D
Deleted member 537459
-wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x 5.6448 MHz SC-cut
1x 6.1440 MHz SC-cut
1x 5.6448 MHz AT-cut
1x 6.2500 MHz AT-cut
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-PPG 22.5792 MHz
1x TWTMC-PPG 24.576 MHz
1x TWTMC-STS-SX
1x TWTMC-STS-DX
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
RG400 is double shielding and lower capacitance.
a pitta ..
Hp
I'm sorry, EU law, in Italy VAT is 22%.
But if you are a company with a valid EU VAT ID there is no VAT.
-wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
1 x TWTMC-PPG 22.5792 MHz
1 x TWTMC-PPG 24.576 MHz
1 x TWTMC-DBM-F 22.5792 MHz to 45.1584 MHz
1 x TWTMC-DBM-F 24.576 MHz to 49.152 MHz
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
Thank you very much! The MPQ is 10.
+1
6.25 also.
- Group Buys
- The Well Tempered Master Clock - Group buy
