This is for test jig/prototype ordering - $8/pcb final cost will remain the same.I was going to mention the Chinese new year but forgot, oops, you found out anyways.
I did sent you a PM asking to confirm my order postal rates. I figured out
$8(pcb)*2 + $2(mcu)*2 + $15.80(cdn post regular parcel to L0E1A0) + $3.00 = $38.80
If you change pcb mfg, I am sure the pcb price will change, so I will wait to send payment until you decide on the pcb mfg.
Thx Rick
I'm making the "big" PCB order once I have a couple of prototypes up and going and the test jig is doing exactly what I want it to.
CFT; 2x fully built
nwboater; 1x fully built
PAID - bk856er; 2x bare PCB + 2x microcontroller
rol; 2x bare PCB + 2x microcontroller
paugie; 1x fully built - 8 ohm
PAID - Nickk; 1x fully built 6 ohm + 1x bare PCB + microcontroller + mixed filter kit + mounting kit
PAID - reo; 1x 16 ohm fully built + add 4 output filters 0.22uf. 1x 8 ohm fully built. + 1 soldered/tested TPA chip and microcontroller.
Krede ; 2x bare PCB + 2x microcontroller
Darkstar52; 1x fully built
Joel Wesseling; 1 fully built 4ohm + 1 fully built 8ohm
PAID - Aterren; 3x fully built (2x4ohm, 1x6ohm) + 2 x board with soldered Micro
PAID - impuls60; 2x fully built (4ohm)
ronu9400; 1x fully built
canzld; 2x fully built
rhing; 1x fully built
shadowlight; 2x fully built
cogitech; 1x fully built - 4 ohm
Hammett; 1x fully built 8 ohm
matt_garman; 1x fully built
kp93300; 1x fully built (8ohm )
linkfan; 2x fully built, one 4 ohm / one 8 ohm + 2x mounting hardware if available,
rsavas; 2x bare PCB + 2x microcontroller
planet10; 1x fully built 8 ohm
pronk; 1x fully built
AudioLapDance; 1x fully built, 8ohm
afoor; 4x bare PCB + 4x microcontroller
moumousganou; 1x fully built + 1x with just TPA and microcontroller solder
FantsicoGrande; 1x fully built 8 ohm
jarrettv; 1x fully built 8 ohm
zoidbergslo; 1x fully built TI soldered + extras for later filter modifications
andrewcorbett: 1x fully built - 4 ohm
finneybear; 1x bare PCB + 1x parts (not built), 8 ohm
PAID - goo: 1x fully built 4 ohm
guglielmope:1x fully built, TI + 1x mounting hardware.
Ians505: 1x fully built 8r with controller
AlanL: 1x fully built 8r with controller
PAID - jagter5: 2 x fully populated boards, TI 6 ohm
vanofmonks:2x bare pcb, 2x microcontroller in bag
PCB4U = best proto price so far, but $80 for shipping to canada? seriously?
Could you have them shipped to one of us in the USA participating in the group buy, and have them send them to Canada for you? Could be a lot cheaper.
I would be happy to do so
CFT; 2x fully built
shadowlight; 2x fully built, (1x 16ohm, 1x8ohm)
Updated my request to include 8ohm and 16ohm boards
Looks good to me, thanks!Can I be added to the list as well for a fully built 8 ohm board ($90CAD) plus Chassis mounting kit ($10CAD) plus small packet international postage to Australia ($11.31 + $3 handling)
= $114.41CAD
Is the above OK ? thanks.
Go red, it's better silkscreen than black. (Thinner and better "sharpness"/kontour at the edges.)
Or green.
Red is faster.
![headshot :headshot: :headshot:](https://files.diyaudio.com/forums/images/smilies/headshot.gif)
]CFT; 2x fully built
PAID - cogitech; 1x fully built - 4 ohm
Right now I've got green terminal blocks, black IC's, gray inductors, blue film caps, silver polymer caps and brown electrolytic caps. I s'pose I could change the input caps to red wima's, get a yellow circuit board and I'd have a harlequin wiener...Go red, it's better silkscreen than black. (Thinner and better "sharpness"/kontour at the edges.)
Or green.
![PIsmFfR.jpg](https://i.imgur.com/PIsmFfR.jpg)
Or not. I'll stick with black. I maintain the dark color absorbs photons that could otherwise reflect and induce circuit noise by the photoelectric effect, 'cause who knows, the occasional photon might make its way through an IC or capacitor package. In doing so it improves the noise performance of the board by 0.00000000000006% or so, which totally makes a night/day difference in the soundstage
Assuming these guys use the same fab as seeed/itead/dirtypcbs, silkscreen quality is pretty much random, but overall pretty decent. I use 0.8128mm, 16% ratio Eagle vector font for component designators and it's always been readable enough to use.
CFT; 2x fully built
rhing; 1x fully built 8 ohm
Update only to indicate paid and TI 6ohm.
CFT; 2x fully built
PAID - matt_garman; 1x fully built - TI 6 ohm
CFT; 2x fully built
Update to add mine (just paid on paypal):
CFT; 2x fully built
vanofmonks:2x bare pcb, 2x microcontroller in bag[/QUOTE]
PAID - zog666: 1x fully built 8 ohm with Chassis mounting kit
CFT; 2x fully built
CFT; 2x fully built
PAID - zoidbergslo; 1x fully built TI soldered + extras for later filter modifications
payment sent
payment sent
After having a chat with the production engineering guys at work, I changed the pogo pin PCB design from "sparkfun style" with stacked PCBs/chinese pins to a single PCB using mill-max 0908 type pins. More reliable, mechanically simpler and I can snag the pins from Mouser along with everything else I need.
With that done, the elecrow order is made - thanks doctormord for the suggestion. Got 50 wiener PCBs and 5 test jig PCBs coming, with 3 day DHL shipping. They return to work on the 25th, 1 week turn on the PCB brings us to march 4th-5th, so PCBs should hopefully arrive on my doorstep monday the 9th.
Here's hoping that crowd making the PCBs aren't hung over after new years![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- Group Buys
- "The Wiener" TPA3118 amplifier card
