hello all the gurus on the diy audio forum trust all is well , my simple doubt is that can a tip 31c npn transistor be used in place of an tip 31a . the poject is a simple amplifier salvaged out of an akai RTR .
regards.
regards.
Yes its fine to use, as are the TIP31B.
The B and C versions have a higher voltage rating, otherwise the same.
In fact cost difference is so minuscule that most big sellers just carry the C , go figure.
I only find the odd A or B in some small town shop, but when I buy straight from Arrow or Avnet, C is always on stock while A and B , although nominally in the list , always show 0 stock.
I think ON or Fairchild call them "preferred device" or something similar.
Simplifies production, stocking, etc.
Personally, at home and at work, I've only ever stocked the better C versions - there's just no point stocking the lower spec ones.
From a manufacturers point of view it makes sense though, if you're buying 10 million of them, and you can save a couple of cents/pence on each one, it's an appreciable saving.
But for a hobbyist, or a service department, it makes sense to only stock the best ones.
