Tone control PCB without capacitors in Cambridge Audio A1 mk3
just curious if someone seen the tone control (Bass, Treble) circuit without capacitors? When opened for fixing Cambridge Audio A1 mk3 I could not believe what I saw...
Did CA invented new tone control circuit which does not require 2 pairs of capacitors and resistors for bass and the same for treble?
Kes
Knobs making some difference but not as expected.
Bass knob makes difference on lower freq. But treble - just a little, not sure if any difference.
So wonder how that even works for Bass...
Definitely need to see the other side of the board...
I am working on what looks like the same model. As you say there are no caps, despite them being marked on the PCB as shown in your pic. I found a schematic online but it does not match this version as it shows caps on the tone board along with +and - 15v voltage regulators. These have been replaced with simple 15 v zener diodes/resistor combinations for the IC power supply. My suspicion is that CA were cuttings costs at this point.
My one had a dud channel and plagued with motorboating and mains hum. I have replaced the two op amps, its a bit better but still distorted. The power amps are OK. There is not much else to replace. Any ideas?
Mine also has some mains hum, which not disappears even with 10000uF capacitors installed, so I have spend some time investigating, seems that mains hum is picked by tone control components which are too close to mains switch, and no shielding, therefore I guess CA removed caps from face side of PCB and installed them on solder side a bit far away from it's original place. Just to minimize hum. Unfortunately it is still there. Hum can be heard only on pause and in close distance. With distance 2m and more you hear something, but not sure if it is hum in speakers or rings in ears...
