2.7 and 2.6 A across R3, respectively to previous voltages.
So… 4.4 and 3.9 Watts? I need to research Ohm’s Law.![Reindeer Smily :deerman: :deerman:](https://files.diyaudio.com/forums/images/smilies/reindeer_smiley.gif)
While I’m educating myself, test speakers are singing sweetly! Sounds LOVELY. And it has an absolutely pitch black background of nothingness.
After about an hour of on-time, it’s warm, but not F5 warm. Definitely under 50C on the sinks.
I’m enthralled! It’s my newest and simplest amp! Thank you all!
You want to measure across R3. Are thise measurements on two legs of R3 with other side of multimeter at ground? And what about R4?R3, 1R: One side is 1.62V, other is 1.48V
If this is directly across R3 and it’s a 1 ohm then 1.62V - 1.48V = 0.14V therefore 140mA bias going through 2SK2087CR3, 1R: One side is 1.62V, other is 1.48V
Something is odd since you also said that you’re getting 1.1Vdc across the inductor. These 159ZC are 0.7 ohm therefore the current going through them to generate 1.1Vdc would be 1.1/0.7 ~ 1.6A
For now enjoy the music but later on I’d be curious to know your bias...😀
As I tried to describe before, my measurements were done across the two pins of R3. DVM leads only on the legs of one R3 resistor. I measured across R3 on one board, then R3 on the other board. I measured for voltage first, then current. It seems I’m in the ballpark because the amp was warm and playing music nicely. I will repeat my measurements tomorrow after the amp has warmed up again.
It sounds FANTASTIC! Thank you for bringing the design to the forum!
My 3U300 heatsinks have 53C at the hottest part of each sink. Everything works wonderfully, so I don't think I will press my luck just yet.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I could use a little more gain with it in my system, but I expect that is just part of the source follower topology. It won't get very loud, but it has just enough grunt to satisfy my listening environment.
ACP+, Topping E30 DAC.What are you driving your amp with?
- Total Domination VFET (TDV) Amp (using 2SK2087C)
