Transistor insulators
Thermal pads should have their thermal conductance in the specifications, usually in C/W
You can calculate conductances for any material from its thermal conductivity:
conductance = conductivity * area / thickness
( works like resistance and resistivity, basically )
With inflexible materials a thermal grease is needed to complete the "thermal circuit" - white zinc-oxide grease is suitable, or the grey aluminium grease.
Looking up a few materials:
mica 0.71 W/K/m
nylon 0.25 W/K/m
alumina 30 W/K/m
beryllia 330 W/K/m
zinc oxide 23 W/K/m
silver 420 W/K/m
You'll see that mica is only a little better than plastics - in fact you might as well use kapton tape as its available in thinner films than mica and withstands high temperatures very well.
The common silpads and similar are rubbery so they fill any air-gaps and conform to the device and heatsink well - air is not a good conductor of heat!
Despite containing metal particles (grey is the clue), the thermal conductivity is not brilliant, so use the thinnest types and make sure the heatsink and transistor have no rough spots.
The ceramic materials are brittle and beryllia dust is very toxic, so not well suited for thermal pads (and they have to be thick for strength defeating most/all of their benefit). Some RF power transistors use beryllia packages for good thermal performance and low RF losses.
The best approach I think is a very fine electrically insulating film on a graphite pad (not cheap). Or a diamond pad + diamond grease (very not cheap).
Spring-mounting is better than screw-mounting, BTW, as it maintains pressure over time and presses over the die, not to the side.
A brilliant idea for light duty applications but what sort of paper and "goop" are you using? Standard photocopier paper, as an example, is too thick for efficient heat transfer. If the paper has been laying around for a while, it will have swollen considerably and you may need to re-torque the clamp bolt(s) after a few thermal cycles to restore contact. That also makes it a candidate for spring clamping.
