Tricks using a smaller enclosure 12" woofer
Final setup. Looks nice enought to me to not need to be hidden with speaker cloth, I'll add it anyway.
I added 2mm foam on all inner sides of the shelf to prevent potential rattling. Zero wasted space (to tight it took >5min of pushing to get them squeezed in).
One of the trial ported fronts came out better than the flush so I used that on and filled in the port holes, made them a different color so it looks intentional =P
Reactions: GM
At last, we can fully visualise your project - and it looks pretty darned good too! 😎
I wouldn't want to hide that classic look permanently behind speaker cloth. I presume you will make removable cloth covered grills?
Reactions: GM
I made a frame suction cupped to the shelves. My cats usually don't mess with stuff like this, but that woofer is very large and eye level for them.
It's ugly, miss measured something as it's 1/2" too wide but temporary and very removable.
I presume your cat is spraying, not peeing. This can be a medical or behavioural problem.
One harmless way to discourage your cat is to spray the grill cover yourself, but with mouthwash!
Cat's do not like the strong smell and will stay away.
Reactions: GM
FYI/FWIW/YMMV; 'been there, done that' with cats and found that adding a glass cleaner (water mist) pump sprayer to a bottle of 3% hydrogen peroxide to spray such areas or disinfect most anything has worked great for me and one of my most useful 'el cheapo' 'tweaks' ever.
Reactions: Galu
this cat "spray" on things on the floor that makes annoying noises or vibrations (like the vacumn cleaner, air purifier, my tower pc after I added a loud twin fan video card). He's never shown interest in speakers but I knew there was a chance a bassy 12" woofer might be a trigger.
Enzyme cleaner will safely un-scent most things. Ill give it more time but its probably not a one time thing.
Reactions: GM
Speaking of which.... recently it was pointed out to me that the 0.5 ohms I've listed all these years dates from when amps still had relatively low DF and other high resistance components (circa 1968) Vs today's super high DF amps, minimal XO losses, so guess some measurements need to be made of today's typical (DIY) speakers to find a more accurate default.
Without getting too weird with the shape (back is a little taller than the front) I got 1.53 cu ft.
The original box 2.06cu ft, Tunning frequency 40hz. Fs is 138hz.
If I adjust the port to tune it to 50hz+ and 1.53cu ft. I have a pretty good idea of what happens bellow Fs (it's covered in detail in 100's subwoofer guides)
This is a full range woofer high end rolls off around 9khz.
How much will smaller enclosure, tuned higher affect the response graph from Fs and up (138hz-9khz).
Am I going to lose sensitivity and add spikes/dips in the response?
Or should I keep it at 1.35 ft³ with the aperiodic design you suggested?
the external subwoofer is handling <120hz, so the woofers low end response is getting mostly filtered... I don't want to get bogged trying to make a cross over for drivers with non-published specs like this one.
If you're using an external sub, then I'd just go for the sealed option and be done with it. Both ported and aperiodic can be a mess with tricky tuning, and I didn't find aperiodic bass to sound all that good anyway. Although there may be potential, so if you're willing to rework some holes and/or a grille covered with layers of compressed felt, then go for it. There may be some higher frequencies leaking out with uncontrolled phase, so use that to your advantage and put it at the back, opposite the speaker.
I was thinking about that after I posted last night.
Valve amplifiers rarely exceed a damping factor of 20, for which an Res of 0.5 ohm would be appropriate.
Transistor amplifiers usually exceed a damping factor of 40, for which an Res of 0.25 ohm would be appropriate.
