I haven't checked lately. I am a bit surprised to hear that.
I think most well known tuner models are off the market now as their owners have probably decided they might as well keep them for as long as FM is still alive.
That's the real reason why they are going that much up in price, they fear they can't get them anymore. That applies ofc only to mint condition units. Ie the Revox B 760 goes for ~500-700€, in prestine/mint condition for 1000-2200€ though.
In America when I was growing up, AM radio (at night) was a nation-wide broadcast for clear channel stations, who were also allowed higher power and a 10KHz bandwidth, plenty for the speakers of the time. Pirate stations across the Mexican border also reached most of the country. FM existed, but it was local (within 100kM) and Fine Music, not the pop music of young boomers.AM radio doesn't provide the bandwidth, the frequency range didn't even close reach the standard FM 15kHz. It was very susceptible to interfering signals and because of the needed bandwidth, its reach was severely limited. The wider the bandwidth, the lower the signal on the receiver. Because of the massive drawbacks of the AM modulation, it was never actually relevant in broadcast history.
Today the world is too (electrically) noisy for AM and modern pop music is industrially produced, so FM has taken its place, especially NPR, local "community radio" and college stations. But there was a time...
All good fortune,
Chris
Thank you for your help19 and 38 KHz inductor:
https://www.roehrentechnik.de/html/nf-spulen.html
10.7 MHz (and 455kHz) inductors/transformers:
https://www.roehrentechnik.de/html/zf-bandfilter.html
other 10.7 MHz and various other frequencies' inductors:
https://www.roehrentechnik.de/html/mini-filterspulen.html
There are more AM/MW inductors and transformers on this site as well as audio (valve) transformers etc. The site is in German so a bit of exploring and translating is needed but I presume one can always send an e-mail to ask for details if in trouble.
'Cause presently I have the related unit on my workbench, I was about to suggest the MPX decoder that German manufacturer Nordmende used in their radios and consoles with the 6/634 chassis (Tannhäuser, Arabella) from 1966 on, but although it uses a ECC81/12AT7 tube as the Grundig shown above, it is far more complicated (involving 10 Ge diodes also...).
Best regards!
Best regards!
Would 6al5 work instead of diodes?
An example:
I found the Dynaco FMx-3 module worked fairly well. It does not drift too much and provides good separation.I want to build stereo MPX decoder (adapter) for my Fisher FM-100 tuner. I was looking for some article in old electronics magazines but until now without any luck.
Circuit is pretty simple as far as a tube decoder goes.
BUT.... the inductors required are pretty hard to come up with unless you have a "donor" unit.
This seems to be a issue with all tube decoders I have come across.
There is lots of discussion on this module on the net so it is well know.
Parts only units are common for the "donor".
- Tubes / Valves
- Tube stereo MPX decoder
