UHE and UHP Bulbs for lCD projectors question help?????!!!!!!
I'm fortune to have stumbled into this site
I just got a ELP 5550 which uses a ELPLP07 bulb assembly, 120W UHE. Would the ELPLP10 do the trick for me? Where is a good place to buy them? The bulb itself can be removed and the face of it is about 2.75" X 2.5".
epson powerlite 710 lamp replacement
i have a powerlite 710 and ive read and done research on this projectors lamps. i agree that it is all a big scam to make other peoples pockets fatter. i was wonderin' which lamp bulbs would be interchangable with the "elplp10" bulb. thankyou
epson powerlite 51c
I'm trying to find a cheaper replacement for an epson powerlite 51c. It's an ELPLP16 lamp, 160 Watt UHE. Just curious, has anyone every tried using a bulb rated for a wattage different than the stock bulb? or is this simply a very bad idea.
Anyone know of any other 160 Watt bulbs made by other companies that I could try? seems as though I could swap out the bulb in the housing. I'm having trouble finding a similar bulb besides the correct one from epson. Thanks.
I have a EMP 5500 Projector with Lamp expired. After reading the forum I ordered a ELPLP10S lamp through ebay, as said it could be used instead of ELPLP06 (original lamp).
The dimensions of the lamps are fairly different. Does anyone have any pictures showing how this lamp was retrofitted to the projector.
Hello Ap0,
I have recently purchased a Epson EMP 5500 projector with a shot lamp.
After reading your forum I purchased a ELPLP10S lamp and retrofitted it to the ELPLP06 carrier and installed into the projector.
I have turned the machine on and nothing has happened. All that is on is the lamp red light indicator. Can you advise?
