I did a version of this that I'm happy to share the KiCad project with you if it would be of any help to you. The PCB design is done, but I never had it made to test to ensure everything will work. I guess I was holding back to try and see if I could fit everything into the magical 100mm x 100mm. 🙂
Sure, that wouldn't hurt. Currently I have the schematic drawn up, footprints assigned, I'm moving a bit slower than I had hoped but now I just need to lay it out. Hopefully today or tomorrow, then I can get a separate thread started so as to not hijack this one from Koifarm's great project.
Shared 🙂Sure, that wouldn't hurt. Currently I have the schematic drawn up, footprints assigned, I'm moving a bit slower than I had hoped but now I just need to lay it out. Hopefully today or tomorrow, then I can get a separate thread started so as to not hijack this one from Koifarm's great project.
I've just started a thread for the PSU board that we've discussed. Let's move discussions about that over there and let this thread continue on in regards to the preamp discussions.
https://www.diyaudio.com/community/threads/the-ultimate-tube-preamp-power-supply.389308/
Is the 4 pole dip switch or minidip switch ? I have a hard time finding mini dip switch. My pcbs also on the way
Just like one of these:
https://au.mouser.com/ProductDetail/Wurth-Elektronik/418117270904?qs=wr8lucFkNMUW2I6n2hVTKw==
Looking good Vunce!
Looking forward to further listening impressions from you about the preamp. Are you using a antek transformer in your linear power supply if so, what model?
Thanks Cambe, I’m really enjoying this combo! The Trafo is an Antek AS-05T240 in the steel case made for it.
https://www.antekinc.com/as-05t240-50va-240v-transformer/
Voltage is a little light after the regulator, 240vdc. I probably have the next size up trafo (AS-05T280) hiding in my stash of donuts to try out.
Look at post 1, with the gerber files you can order your own PCB for a view euro's/dollars.
I use JLCpcb. Just upload the files, choice color and you get a quote for 5 PCB's.
Try ECC88 (6N23P, PCC88) instead of 6N6P.Koifarm,
Your pcb design is sounding very good as my AD1862 dac output stage configured for SRPP with 6n6p tubes and a linear psu.
I had high hopes for the imported little SMPS but it didn’t work out. I was getting an audible low frequency warbly tone plus higher frequency noise heard from the tweeters. I swapped out the SMPS and replaced with a regulated linear HV/LV supply and voilà!! Dead silent background and sounds very good to my ears.
Thanks again Koifarm!
6N6P is a good tube, but more for buffer or line stage , but for DAC, especially after the passive I/V stage, you need a finer tube with higher amplification.
With passive I/V, you should go with the smallest possible resistor, because increasing the value of that resistor increases distortions. You can install 100R trimmers and find the sweet spot and then replace them with resistors.
I think the AD1862 could work with the 50R as well.
Hello
Is this relay suitable alternative ?
https://my.element14.com/axicom-te-connectivity/im03dts/power-relay-dpdt-5vdc-5a-tht/dp/3702839
Thanks for help
Thanks for help
I don't think so, the pins look to not be the correct spacing - see the data sheet for the original circuit. I have chosen an Omron G6SK-2-H-DC5 as I could not find the original relay specified in post #1.
This is the relay I used:Hello
Thanks for help
https://my.element14.com/kemet/ec2-5nu/relay-signal-dpdt-250vac-220vdc/dp/2360823
Hi Gary,
Thanks for your reply.
No stock of Omron in Element 14 malaysia .
Please look at the datasheet for TE range.
Is the model RT424005 suitable alternative?
Otherwise, any serious problem if l bypass the relay?
Tube are not too expensive anyway
kp93300
kp93300
No it isn't, still wrong pin dimensions. You need a relay with pin out dimensions as shown in the original relay or in the ones linked by myself and Vunce.
The relay mutes the output for a time delay while the tubes warm up - tubes wont be damaged, more of a problem for the following power amp and speakers, or turn on the linestage first, wait 30 seconds or so and then turn on the power amp - reverse order when turning off the system.
Gary
Thanks for response. I will order the Kemet and wait for the back order of about 1 month from element14
I believe its very similar, if not the same, as the SMPS you were working with.
Same board setup different parts.
- Tubes / Valves
- Universal tube preamp PCB, ECC99/6N6P/ECC88/ECC85/6922/6DJ8 etc. MU follower or SRPP
