Nice work!New version was born. Output is 140W/8ohms before clipping.
Sajti
140W RMS/8R using +/-40v?
Nice work!
140W RMS/8R using +/-40v?![]()
No, that was wrong label was not change on the pcb plan. It runs with +/-56V.
Sajti
OK, i will try again. Thanks Sajti,
Your amp make me feel pleasantly. I wonder how about if it run LMOS as output devices?!
Regard,
I know one version which is running with IRF240/9240. It is necessary to modify the Vbe multiplier, and You dont't need the double emitter followers as drivers. Single is enough.
Sajti
The latest version is ready, and running since 2 days. 60W/8ohms and 110W/4ohms, dual mono.
Bias was set to 70mAfor each output devices, 77mA on the cold amplifier, falls down to 68mA after some hard running. Output offset is 25mV when the relays turn on, reducing to 5mV in 30 seconds, and finally down to 1-2mV after 5 minutes.
2x200VA toroidal tansformer, 2x40000uF in the PSU. Sanken output devices, Sanken drivers, Toshiba and Fairchild in the front end.
Sajti
Sajti
Nice work!
Are these heatshinks big enough for proper cooling?
I use the Fischer SK595 heatsinks. There was no problem with the cooling, even my speaker has the minimum impedance 3,7ohms. The backplate also acting as heatsink. It is 5mm aluminium sheet.
Sajti
- V6 amplifier
