Valve DAC from Linear Audio volume 13
Looks like a good start Marcel, I'll sort out some content for you to add around ordering the parts.
BTW, I've been a bit concerned about Dan (snax) and managed to find his mobile number in an old mail so we've just had a chat. Thankfully he is well but has been stuck outside of the country - he's now at home and sorting some things out. He's not completed his build (and it's not on his priority list at the moment) but he's going to drop by soon.
diyAchim - 1 x PCB - 1 x SMD Parts installed - 1 x Filter PCB (pair) - Country = Germany
Raj!1 - 1 PCB - 1 x SMD parts installed - country = UK
dubulup - 2 x PCB - 0 x SMD Parts installed - 2 x Filter PCB (pair) - Country = USA
ericoto -1 PCB
HenSch - 2x PCB, 2x Filter PCB (pair) country=Germany
mterbekke - 2 times everything (2pcb+soldering+filter (Netherlands, confirmed)
rfbrw - 1 PCB Filter PCB 1 set.(UK)
Pistollero - 1 PCB (Portugal)
luchoh - 1 PCB + 1 SMD Parts installed + 2 Filter PCB (USA)
pgour - 1 PCB
agent.5 - 1 PCB + 1 SMD Parts installed + 2 Filter PCB -> USA
spm - 1 PCB (UK)
torb - 1 PCB (Finland)
thuanth43 - 1 PCB + 0 SMD parts installed (Singapore)
Offline from now on until September 4th, as discussed, Ray.
Hi All,
A bit late to the party but I'm in!
ericoto -1 PCB
pgour - 1 PCB
spm - 1 PCB (UK)
Kcom00 - 1 x PCB + 2 x Filter PCB (Australia)
Has anyone looked into attaching a AK4137 board to this project?
(Something like AK4137 I2S/DSD Sample Rate Conversion Board Supports PCM/DSD Interconversion DOP | eBay).
Would that enable via an I2S converter to connect an external S/PDIF device?
Steve.
ericoto -1 PCB
pgour - 1 PCB
spm - 1 PCB, no SMD, 4 x filter PCB (UK)
I'm keeping an eye on ppy's latest project too - looks interesting.
As you would expect there are some cheap Chinese AK4137 boards available on ebay - no idea of whether they're any good. I'm not reccomending them, especialy as I have no experience of them - just pointing them out as, perhaps, a cheap starter option for delivering DSD data to the DAC;
AK4137 DAC SRC Board Digital High-End Audio 786K 32Bit DSD256 DSD IIS Conversion | eBay
Attached is the latest position with my GB spreadsheet.
Three initial subscriber's haven't reponded with their choices yet so I've zeroed their quantities so you guys can see the ballpark costs if they've fallen by the wayside.
I'll provide info for Marcel to include on the first post about my reconstruction filter PCBs but here's a heads-up on the custom-wound inductors I designed the PCB to use;
Custom Inductor RM8 Core, 34,58 €
There are price breaks for quantities.
Also, remember that the PCB is for Lundahl LL1684 transformers.
I guess you might be able to use different inductors/transformer with the PCB with some bodging but I can't comment/help with that possibility. If you're not going to use the same inductors/transformers as I did you might want to think about an alternative approach to the output PCBs I'm offering as part of the GB?
diyAchim - 1 x PCB - ? x SMD Parts installed - ? x Filter PCB (pair) - Country = ?
ericoto -1 PCB
pgour - 1 PCB
spm - 1 PCB (UK)
torb - 1 PCB + 0 SMD Parts installed + 0 Filter PCB (Finland)
A cheaper alternative could be to buy RM cores and to wind them manually. It's more fuss because you need to separately buy the cores, the clamps, the coil formers (bobbins) and the enamelled wire. The Digikey part number for the cores is either 495-76950-ND or 495-76953-1-ND and the manufacturer's (TDK's) part number either B65811J0250A048 or B65811F0250A048. The J model has no centre hole and the F version has a threaded sleeve.
ericoto -1 PCB
pgour - 1 PCB
