Yes this is the question, in LR2 is normal to see that be reverse the polarity of the tweeter and I did not know why.
I understand that to have the best sound is better to design a crossover to try to keep the same polarity of both drivers in two ways.
I think you know the answer already. Yes, it is strange to me too that this phenomena is not communicated well but still you can see the majority is following the "norm" correctly... (And by observing some phenomenon in commercial devices, my prediction is that engineers know what to do, it is just that these things are not communicated, especially in forums like this).
IME, whichever the driver that is inverted, it has been compromised. Bass is so important so normally you don't want to sacrifice the bass. But in a very good system (with good *dome* tweeter), often I feel that sacrificing the tweeter is unacceptable too. So I have NEVER made a 2-way with inverted drivers. But 3-way is a difficult case...
But remember that eventually we have to make trade-offs... Sacrificing what has to be sacrificed in a bigger whole system... Amplifier inversion is also part of the scheme. Or, inverting can sometimes be seen as opposed to compromise. Sometimes, it is better to "invert" the signal (locally or globally)...
X, absolute polarity simply doesn't matter.
That's a statement I've seen little research on, but it would be very interesting to do some absolute phase tests. If only I had friends who were blind and would let me put blind folds on them I could tell you for sure. So much research depends on double blind people I'm surprised they don't make more money.
There's a lot fewer blind people out there for these tests than you'd think. I tried to do a double-blind test and put an ad out in the paper for blind people. Not a single reply.
Erik
I would highly encourage everyone to read this thread by Speaker Dave:
Crossover mods for the AR4x - Mods, Tweaks, and Upgrades to the Classics - The Classic Speaker Pages Discussion Forums
It is internet golddust. He clearly explains how phase overlap works. The OP might be interested in the 3rd post. "Best phasing in a system depends on a lot of variables including woofer depth, crossover order, crossover frequency, etc. you can't generalize and generally must use the phasing that gives the best addition."
Erik
It's easy to test. Switch polarity on both L and R speakers and see if you can detect a difference.
Surely you jest about finding blind people. Double-blind testing means the subjects can't see the products being tested and the person conducting the test does not know the identity of the problem (to prevent him/her for subconsciously influencing the test). In this case, just not knowing what the polarity is or if it has even been changed should be enough. There will be no difference guys, think about it. I can't believe we are even debating this.
Of course I jest. 😀😀 I was making fun of people who can't see what's before them or anyone else unless it's in a double blind study. Whether absolute polarity makes a difference is something I have simply not tried to consider. It's best for me if I can't tell. It's less expensive that way. Otherwise I'm going to have to start worrying about time and phase coherent designs.
Best,
Erik
A resonance is dependent on the cycles and there are several. I have doubts as to the audibility of half, but an inter driver cancellation could be a problem.If you put negative of amp to positive terminal of woofer, a signal intended to cause driver to push out on kick drum will suck in. This is not how the kick drum feels or sounds. The 180 deg phase flip has everything to do with rarefaction vs compression. If it did not why do we have positive and negative labeled terminals on drivers and amps and signal input cables?
A lot of misinformation and conjecture in this thread.
Reversing the polarity of the tweeter simply changes the phase. What is phase? Phase indicates the relative time arrival of frequencies. Note the word 'relative'. If you had flat phase, it means all frequencies are arriving simultaneously. Crossovers introduce phase warps. Higher the order of the crossover, greater the change in phase.
In a typical two-way, you are looking for phase overlap between the two drivers in the crossover region. Remember that the total output at a frequency near the crossover is the vector sum of the woofer and tweeter output. So, if you have the tweeter output 180 degree out of phase with the woofer, you will get perfect cancellation. If it's in phase, meaning the phase responses of the two drivers overlap, you will get a perfect sum. If it's somewhere in between, you'll get non-perfect addition and subtraction as you move through the crossover region.
Ideally, you want the phase response of the drivers to overlap through the crossover region, maybe until the drivers are down by 24-30 db. This will give you a nice sum. Of course, as you get off-axis, you might notice a dip near the crossover. This means that at that frequency, your drivers are out of phase. This happens because relative to your measurement point, the drivers center to center distance has changed. For example, if you measure up, then the tweeter is closer than the woofer. This will cause the tweeter frequencies to arrive earlier than the woofer frequencies at this measurement point, i.e., a change in phase overlap.
So, when you reverse the polarity of the tweeter, all you are looking for is whether the phase overlap through the crossover region is better. Flipping the polarity changes the phase by 180 degrees at the crossover frequency -- kind of a crude tool, but a tool to improve the crossover nevertheless. Crossovers and other filters on the other hand can change the phase in smaller increments.
Flipping the polarity has nothing to do with compression and rarefaction of waves. If you experience a better "transient" response by flipping the polarity, what you are really experiencing is a better phase overlap, which results in a flatter response (less undulations through the crossover). If you have excellent phase overlap between the drivers, it can sound really good-- like a single driver -- and it will be almost impossible to tell where the crossover is.
EDIT: A point about waves. Normally, we need several cycles of a frequency before we can tell what frequency it is. Basically, we need to hear the frequency for a while before knowing its identity. When a drum is struck or a piano note is struck, it's not like only a single cycle is emitted. Hundreds of cycles are emitted. For example, you can fit 20 cycles of 20 Hz in one second. With some software one could experiment how many cycles at 20 Hz are needed before one can discern that it is 20 Hz (and not 30 Hz or 40 Hz and so on).
This is all if the intended design is of the LR even order alignment type. If you are doing a BW4, remember they are out of phase by 90 degrees.
Later,
Wolf
If you are old (experienced), sometimes you don't need to do a test, because too many experiences will give you a conclusion of statistically high confidence.
There is a thread where PMA posted two files regarding absolute phase. I could do 12/12 of Foobar ABX with those files. In reality, the difference is IME always much greater than those two files. It depends on the music/recording (usually in bass performance), may be also on the speaker.
A member, Max, even mentioned that it affects the soundstage (I have never noticed because my critical listening in real life, including ABX have been always in mono).
I have a neighbor friend who seems to be more superior than I am in detecting phase reversal. He is around 55, making a living from selling used audio stuffs. Of course my ears are better than his, but often I'm amazed when I connect a cable (with no sign for plus/minus) to a speaker and upon a few seconds of listening to the speaker he commented "The cable was inverted...". This happens very often. I mean, how can he do that, even without comparing...
That's what I mean with experience. Once can be a coincidence, twice can be still a coincidence...
Interesting, Jay! I'm curious, did you have a preference?
Erik
Hi Erik,Of course I jest. 😀😀 I was making fun of people who can't see what's before them or anyone else unless it's in a double blind study. Whether absolute polarity makes a difference is something I have simply not tried to consider. It's best for me if I can't tell. It's less expensive that way. Otherwise I'm going to have to start worrying about time and phase coherent designs.
Best,
Erik
you did not get a response from double blind people in the paper because obviously they don't read it. 🙄
I have a question. If you are deaf in one ear should you rather listen to mono?
Actually no, you need two ears for direction, but one ear can tell dept.
Hi Erik,
I think you are the only one who got that part Nico!
I'm not sure that's entirely true. A lot of work in Head Related Transfer Functions (HRTF) implies that with one ear you could tell more than just distance, but I don't claim mastery over the subject, just that I would not be surprised if it was possible.
Best,
Erik
Since the detection (i.e. halve-wave rectification) process in the ear is asymmetric, absolute polarity might probably matter more than some think.
The OP's question has already been answered correctly halfway through the thead in one of the shortest posts: Yes, by having the polarity of the woofer correct in a usual two-way speaker it is guaranteed that the absolute polarity of the largest part of the spectrum is correct. And also throughout the part where there lies the most energy in usual source material.
Charles
Charles
Tomorrow I will do three test with my friends
Currently in this speakers the woofer is (W) wire + (D)driver + and tweeter is inverted W+ D-
Test 1 change the main wires amp to speaker polarity W+ S-
Test 2 invert woofer W+ D- tweeter W+ D+
Test 3 without change Woofer W+ D+ Tweeter W+ D-
I think that is difficult to ear the changes, In my last test with myself , I listened one week with the woofer inverted and don't remember any big different, now the XO is at 1.8khz, tomorrow the test will be with the piano playing in this frequency region and same orchestra with percussion will be very funny to see what happen.. I
Consider the drummer himself.
On his side of the kit every drum hit starts with a rarefaction.
Furthermore in most cases when recorded, drums are close mic'd from the top and thus most drums we hear on recordings start similarly with a 'suck' rather than a 'push'.
(Kick and snare are frequently mic'd from both sides. The engineer will usually flip the phase on one of the mics. Which one he flips or if he flips at all is a matter of habit, his preference of what he hears at the moment or the tide in Abergavenny.)
FWIW last time I walked around a drum kit being played it did not sound remarkably (or unremarkably) different from behind (rarefaction first) or in front (compression first) of it.
Charles, I think the issue is not with the source, but with the loudspeaker mechanism. May be it is not a problem at all with planar/electrostatics...?
Jay, I disagree with the idea that a speaker should radiate like an instrument. If we were in an open space then any consistent source will get the sound to us. The difference is how much the room gets involved.
Preference about what? Inverted versus non-inverted of absolute phase?
In absolute term I prefer non-inverted, because the dynamic/sonic/drive/control is better. But there are minor cases where inverted can be good. For example, most midrange drivers are usually the weakest point of 3-way speakers. Often it is preferable to "calm down" the midrange, e.g. by running the midrange inverted (but I don't know if this could harm the soundstage or not).
Lately, I tried to find the best opamp-based preamp (I'm not an opamp guy, but I have plenty around, so this was more for fun). I used my ears to judge the results. Tried several opamps and find the best implementation for each. Tried several gain structures. Prior to that I started with finding the best power supply, including the components...
Between Wolffson DAC and TDA2030 amp, I tried 1/2/3/4 opamp stages in series with a potentio-based volume control. To my surprise, 4 opamps was better than 1 opamp (or 2 or 3). And I couldn't make a globally non-inverted scheme to sound better...(yet). But I didn't try to invert the speaker cable tho...
What I mean is... I thought the audibility of absolute phase is because of imperfection in driver mechanism. The driver (and complete loudspeaker) is not symmetrical. The sound of the cone moving forward is not the same with it's sound moving backward...
- why tweeter is normally wire inverted to correct the phase
