Thanks Andrew,
I listen a lot to BBC Radio 3 music programmes. A constant source of annoyance is the BBC's total disregard
for phase and even correct L-R channel positioning. They blame the 'phone company whose lines carry the BBC
programmes to the local relay stations.
Would it be possible to have phase and channels switchable without increased design problems/vast cost implications?
Thanks again,
Brian
Thanks again,
Brian
I'm happy with the modular approach but tend to balk at the hard wiring approach. My preferred wiring uses the likes of Molex KK 254 board connectorsI think a lot of folks balked at the inter-module wiring hence the alternative approach.
Brian, yes - I will add that feature.Thanks Andrew,
Thanks again,
Brian
@Bonsai - a few days ago - on another thread - posted that he would be away for a few days. I am sure that you will hear from him soon.Are you working?
Bonsai,
Loving the preamp but it still has some bugs and I need to open it up to make some changes. I will add the inductor to the headphone amp to keep it current though I use another external headphone amp. When I use the balanced out it pops when I mute the volume, I did not ground the balanced plugs to the circuit board so I need to see if that fixes it ( though again I use the single ended out mostly) and most annoying when I touch the unit and there is any static discharge the unit switches itself off, any advice would be appreciated.
Bill
Bill
High Kedar10, can you confirm what you ordered then I can check for you? Apologies for any problems.Hi Bonsai,
I made a purchase from your store yesterday. I have no order confirmation from you. Are you working?
Andrew
- Analog Line Level
- X-Altra Line Level Preamp
