Yes detached house with two floors. I installed sound isolation double-door between the floors, hifi room is in the basement that is partially under the soil. The separate "guest house" has even greater sound isolation😊
Ushers look so good that I cant put colossus back in anymore😅 The low q sealed setup also does not go deep enough in this big space, with 3-way active would work better.
Old pic with feat. Logans
Vent the FC-123F02s and put the cabs on massive stands?
Congrats Legis for the house, nice area.
I like the brick walls, were the bricks there or did you add them as decorative ? Ziegler sorta carpets are nice, very warm living room
ahaha the Logans seems toys in front of the Ushers, does it sound better in the mid-treble range ?
The original builder has done the brick wall. The basement is made of "stone" bars and concrete, the brick upholstery is just for the looks but they are real bricks, not "fashion bricks". Contruction specific english not my strong point😂 This room was originally a billiard room. The main living room is upstairs, i have small white genelecs there😁
Persian carpets are the best. These are huge 3x4m and weight like 60kg per carpet. They are from 80-90's iirc, bought them second hand. They can last for decades or even couple centuries if looked after properly.
Venting them has crossed my mind🤔 Maaybe at some point.
The FC-123F02 is designed for ported enclosures. What's the capacity of the mid modules, around 250-300 litres?Venting them has crossed my mind🤔 Maaybe at some point.
I'm pretty sure venting the mid modules will lead to good results. 4x FC-123F02 in 300 liter BR gives an almost ideal -3 dB of slightly above 50 Hz.
However, I like the parameters of the old version even better:
![1672027228048.png 1672027228048.png](https://www.diyaudio.com/community/data/attachments/1030/1030973-4f10a7fd855a46bdfc5d30b6a04ba244.jpg)
- resonance frequency fs = 34 Hz
- impedance R = 8 Ohm
- sound pressure level SPL = 97 dB (2,83V; 1m)
- DC resistance Re = 7,8 Ohm
- force factor BL = 19,26 N/A
- voice coil inductance L = 1,1 mH
- effective mechanical mass incl. air load mms = 84 g
- equivalent volume of compliance Vas = 238 l
- total Q factor Qts = 0,35 (Qms=3,92, Qes=0,38)
![1672027205899.png 1672027205899.png](https://www.diyaudio.com/community/data/attachments/1030/1030972-22ad4b01285c9e57d0d990d212f82944.jpg)
Great Driver. I have used the 4ohm version and it was lovely.However, I like the parameters of the old version even better:
View attachment 1123063 View attachment 1123064
- "Shadow of The Colossus" build thread
