I gave up on beating ZM long time ago, no chance. Once i reach 10k, i will stop bugging people here on this forum. To be honest, i am very happy with sound of my systems. Just building stuff is fun. Giving most away to friends anyway. It gives me pleasure building stuff, measuring it, listening to it, comparing it to other stuff...having fun with it. Music can be such ecstasy.
Reference my post #3,689 ......
I've been looking at @voxxonline's 'problem' with his Wolverine - reference his posts just before mine. He sent his amp to me to fault-find and in case this may assist anyone else on the forum this is what I've been able to conclude:
He felt that 'something happened' as he was connecting his speaker wires, because inadvertently the amp was still turned on at the time. Only one channel was believed to be affected. He was aware that the speaker binding posts were not good and needed to be replaced, and this indeed was the source of the problem I believe - any very slight movement caused the posts to short out onto the chassis rear plate.
Symptoms:
I used a 'bulb lamp tester' and, when power switched on the lamp was brightly lit and 'pulsing' rapidly. Immediately switched power off and measured the boards - one channel direct short between speaker + to both V+ and V-, other channel looked OK.
Resolution:
Process of elimination, found output transistors Q110 and Q113 both short circuit, remaining transistors suspect. As a precaution, all output transistors replaced with new. Switched on again to test, and 'pulsing' still evident. Further process of elimination revealed Q104 (VBE) also 'blown'. Replaced Q104 with new - all now working as expected.
Testing/setup:
Ran through the set up from scratch for both channels (5v, bias, DC offset) - all good. Played some music to test and all now seems to be fine!
Conclusion:
Suspect speaker binding post(s) shorted to chassis, which caused surge/spike and blowing of output and VBE transistors.
All's well that ends well.
Moral of this story - make sure your amp's turned off before playing around with wiring and connections!!
Symptoms:
Resolution:
Testing/setup:
Conclusion:
Please see 1st attachment on the 1st post of this thread. There is no ‘best’. There is ‘most optimum’ for your existing speakers, listening position and overall SPL needs/desires. Once you know the overall speaker impedance and sensitivity we can help you make a determination assuming a 2ch setup.Please inform me what is the best supplying voltage to obtain the best performance outcome specifications
Best,
Anand.
Not quite sure what you're asking, but no difference in relative performance between supply rail voltages. A 71VDC supplied wolverine vs a 54VDC supplied wolverine built with identical parts* powering the same load 1W or 100W will have identical objective distortion performance. Lowering the voltage lowers the cost, (slightly), improves longevity (slightly), and lowers output power, and maybe (speculation, not proven) reduced PS noise.I know
But I want to have the objective specification outcome, not related to environmental and subjective environmental factors
But there's no sweet spot. Like others said, the "sweet spot" is how much headroom you need for your speakers.
Roll speakers lots? Use 71VDC rails
*Use the same board, only swapping the voltage dependant parts - CCS, DCO & Cap Multiplier resistors
- DIY Class A/B Amp The "Wolverine" build thread
