Full Range Speaker Photo Gallery
Reactions: 4 users
Re: Hafler differential cross-wiring, what threw me at first was the subtle symmetry-breaking. The center speaker wired one way or in reverse-polarity actually decided the front speakers being L | R versus (-R) | (-L). Spooky action at a distance
Last night I did a tilted-back Tangband W3-871SC Haffler Differential (msg #5216 @MITsound) 3.1ch 1ft "console" experiment; good floating-in-air soundstage width and even better depth. But switching center-driver polarity did not left-right flip the stage as I had theorized above; one way did sound much thinner.
In the spirit of Minimalism here are two more up-firing XO-less speakers: from Taiwan 8" Hicastle bicone virtual sonic clone of my Lowther PM6A (but only cost $50 due to cosmetic blem.); and WAW 12" Aura ($50 oldie) supporting Mark Audio Alpair10.3 stainless balls variously sold as buffet server/tabletop trashcan/ashtray (really). All these drivers seriously overreached their highs. The Hicastle tea strainer placed over needle-nose phase-plug (and a holey grille) smoothed out the top end as well as vertical directivity. The scarf low-pass Aura and (very carefully) rotatable A10.3 wired in series are perfectly balanced solo & accompaniment. Sure I can nitpick but these aren't easy to beat.
Reactions: 1 user
I have to say I'm rather surprised by the SQ of simple up-firing quasi-fullrange drivers. Possibly the best yet -- and cheapest at $35 total -- old 10" GuoGuang (aka Pearl River) ringed paper cone "woofers" placed atop ~27L "retractable" metal-and-plastic garbage cans. Snuck under-desk for some boost, they fully resolved deep bass drum roll etc from my Classical acid test, Karajan's Dvorak 9th (near the 40-minute mark). A slightly dry-ish sound not yet "lean", very taut and clear. Mids clean and detailed as well. Highs extended near 10khz at an extreme listening angle of 60-80deg off-axis, even fairly flat. The previous owner had cut away the soft dustcap entirely and glued a small piece of foam to the center; hence too much HF if mounted on baffle even without toe-in. Perhaps I will mate them with ultra-fi mid-tweeters like FE108eΣ or MAOP5 or SB Satori to aim for a perfect zero score. As-is playing under a table, -3 score (hi/mid/lo) A-/A/A+ which is pretty uncommon regardless of cost.
Reactions: 1 user
I found a pair of favored, and just lightly used, Fostex FE108EZ 4" full range drivers and bought them. I've begun expansion of the Nest Music Theater to 5.1.2 and need ear-level surrounds. I built a pair of ~5 liter miniOnkens from 15mm Baltic birch remnants from prior builds. These keen tiny full range speakers are awesome from 70Hz-15KHz, despite perfection requiring a much larger horn or transmission line cabinet (which'd be inappropriate for the surrounds locations). The full build & 5.1.2 story is HERE if you wanna wade it.
The suspended "front presence" or "height" speakers in the NestMT picture above, FPL/FPR, which are the ".2" in a 5.1.2 config, are cool too. They are ~8 liter bass reflex cabinets for the wild Tang Band W4-2356 full range drivers, retired from my Blanda bowls. I call them Tang Band Tri-Ports. During the build I measured both the sealed version and the final tri-ported version. The 2nd SPL sweep in this post shows both "Tri-Port" variants ~ there's notable bass improvement with porting. Ultimately they are pretty smooth too; this after I re-teased and reduced the acoustic stuffing. They are not as nice as the Fostex's at the mid-high end though.
Reactions: 1 user
