F5 Turbo Builders Thread
Joined 2019
This also an exercise for me to learn and for fun vs. a definitive answer. I welcome corrections / additions.
2 N and 2 P boards per channel...
0V370 (if you had 0.370mV, that'd be pretty pitiful) ;) across 0R5 (I think the test points measure the equivalent of the points across both source resistors in parallel for each output device. So, 0A740 per vertical set. 4 Vertical sets per "phase". 4 Ns and 4 Ps. => ~3A => 6A of "Class A current" before we go klunk with push/pull.
Rails +- 48 less ~4Vish in loss => +- 44V => running balanced / differential => 88Vp => 176Vpp => ~62Vrms before voltage clipping.
Into 8R you're going to go klunk before you hit the rails.
6A gets you to ~290W into 8R
I screw this up ALL the time.... so, someone will likely be along momentarily to fix my errors. BUT... that does seem to agree pretty well with the article... So, I've got that goin' for me... which is nice.
Edited to fix some silly autocorrect... LOL!
Reactions: 1 user
Moderator
Joined 2002
Rule of thumb is that each pair of BL JFETs are sufficient for 2 or 3 pair output. More than that is better served with more devices.
As you add more input (or output) devices in parallel, the open loop gain drops a bit because the drain resistance has to become smaller for the same Vgs, and more pairs also require less Vgs. The gain of the first stage is approximately drain resistance divided by source resistance. This is slightly offset by the increased transconductance of the (bigger) output stage.
Best to put it on a sim, but if you have no problems with 4 pairs and a single input pair, you should stick with it.
  • Thank You
Reactions: 1 user
What would be the best approach for adjusting P3 on a balanced F5T with connected feedback loops - feed a symmetrical signal into the amplifier and measure/adjust distortion for each "half channel" output vs. ground, trying to get similar distortion characteristics for both halves? Or is it better to "separate" both halves prior to adjustment by grounding the feedback loop...
Sven
Joined 2013
I don't know if this is the best way to adjust P3, here is how I did it on mine. The Akitika 2ppm 1K sine wave generator has a cable with two RCA's going into the XLR (Amazon under $10 USD) which feeds the amplifier XLR input. The amplifier speaker output to an 8 ohm load, which then feeds a voltage divider to a Behringer UM 2 sound card. The sound card has a USB output to my laptop with REW software for FFT.
BEFORE I connect the sound card/voltage divider to the 8 ohm load, I adjust the Akitika for 2.83vrms into the 8 ohm load. This gives the 1 watt output into 8 ohms.
The voltage divider is set to output 1 vrms into the sound card, any more than that could fry the soundcard (did that once). Building the voltage divider is lots cheaper than buying soundcards.
Since there are two P3's to adjust, I have a note pad to record which P3 I adjust and how much (quarter turn, half turn) and which direction (CW vs CCW). It keeps me from getting lost with these adjustments. It is possible to get 2nd order distortion, just beware the adjustment can be positive 2nd order or negative 2nd order. REW FFT software shows the phase angle for 2nd, 3rd, 4th, etc.
It took me a full day to adjust, 2 hours to get the amps to operating temperature, and usually 15 - 30 minutes to stabilize after each adjustment.
The 2 hours to get the amps temperature stabilized is from the FirstWatt F5 owners manual.
Reactions: 1 user
Thanks for your answer. I'm a complete layman but this raises a few questions for me:
With your approach you don't really "see" the distortion of the two halves of the symmetrical amplifier individually, you align them roughly by turning both pots equally and only look at the sum of both halves. That assumes both amplifier halves are somewhat equal to begin with which is probably unlikely, so you will have two halves behaving differently and doing different things to the positive/negative half of your symmetrical audio signal?
I was considering to create a similar distortion spectrum for each half, and then in a second step look at the "sum" of both halves which will change distortion spectrum again because some will be cancelled out. I wanted to avoid distortion as a result of adjusting halves differently... but perhaps I'm overthinking this?
Also, the signal you feed in is presumably not symmetrical but in phase, a symmetrical amplifier would probably try to cancel that out - so the "sum" distortion of the symmetrical amplifier from that signal which you see on your graph would not be the same as the distortion from a 1khz (or more complex) symmetrical audio signal?
Sven
Here is a little datapoint for you. Next time you have the Akitika out to play, set the volume control on the Akitika to an arbitrary level (say 1V RMS or 2.8Vpp) and then measure the voltage outputs using your analyzer.
What I found was each of those RCA outputs had different distortion levels which shocked me. They are not the same. Moreover the voltages on each of the outputs were not exactly the same either (but close, so a non issue).
On a scope, each of the RCA outputs had the same waveform. One was not opposite in phase which is what you need for a true differential input source.
For me, the RCA output closest to the volume control had lower distortion so I use that exclusively if I need to use the Akitika. Unbalanced source only.
For reference, I am using the QA403 analyzer.
Best,
Anand.
Reactions: 1 user
Joined 2013
No, I'm adjusting P3's so my desired 2nd order and 3rd order are on the speaker outputs. I have no idea if each phase is equal, nor do I care. I only care about what is present going to the speakers.
This is how I adjusted my Balanced B1 Korg preamp, I'm VERY happy with that preamp.
The Akitika distortion is 2ppm, I don't think I can measure that let alone any cancellation. The sound card is good, not great.
Yes, that is a "hummer", I have several (8) of these in other constructions and they hum a lot - but mostly because they are extra sensitive to DC. Lately I have had so much DC on the net that even one standard bridge will not remove it all, and they hum again.
I had a small one in my CD' player where the problem was solved with softer damping, e.g. mechanical issue.
I have had less hummmmmm with Toroidy and Sedlbauer's "premium" series. - And even more with Talema 1Kva
Hope that helps
Did you mean Talema hum more than the Toroidy or him less than the Toroidy?
Thank you very much for your clarification, I presumed what you meant by black version is the potted special audio version, but without the stainless casing.
Yes, exactly - the potted black tape wrapped version.
In the picture below, these are smaller than the Ulveco's by 100VA (need to stay within the diameter)
But the favorable direct comparison to the Talema 1000VA was a with a 1200VA Toroidy replacing it - (Installed in the same Threshold S200).
Reactions: 1 users
I am not familiar with the Sedlbauer transformer. I was speaking if of the same quality, preferably the same manufacturer, then the larger VA sounds better. If the Sedlbauer 1000VA is the same quality as Toroidy, has the same specs etc., then bigger is better, (if you can still lift the finished product.)
Rush
Reactions: 1 user
Hello NE WAY,
I have used so many Sedlbauer - transformers, that I don't know how many any more.
In my F5Turbo - Monoblocks I have used 1000 VA transformers from Sedlbauer - excellent
quality!
But I am sure, that the TOROIDY are on the same quality level. Very nice are the potted TOROIDYs (supreme audio) in that beautiful shiny encapsuled stainless steel cases...
Chers
Dirk
