I'm looking for a high voltage tube for my next gen ESL direct drive amp.
Basically Va(max) at least 6500V, with a Pa (max) of at least 50W.
Everything else is negotiable but preferable not one that requires me to take out a 2nd morgage ...
Jan
Jan
Hi Jan,
very interesting project... I also thought already about how to build such an amp... I would try a 4-125A (QB3/300). Max. plate voltage for RF power amplification should not exceed 3 kV (datasheet...), but from its construction its plate can take a lot more.... Max. screen voltage up to 600V, with such high plate potentials I would rather go quite a bit lower, 200-300V. Graphite plate and very rugged construction, so I think this would be a good beginning at least... But how do you plan to realize the plate resistances? Resistors, chokes?
In this way I also operated an EL81 with up to 1,2 kV DC plate voltage (and 70V screen) as a regulator tube for a power supply, which could be set from 800V to 1,2 kV output voltage using an EL519 as pass tube.
If it should be a triode, I would eventually try the former colour TV HV shunt regulator triodes like the PD500..... Maybe two or three of them in parallel?
all the best
Uli
@tubeampuli
all the best
Uli
@tubeampuli
Interesting..
If you need high voltage transformer-rectifier-capacitor Look at this Danish add.
https://ham.brugtgrej.dk/annonce/191702
Heavy stuff
Heavy stuff
No I hadn't Patrick. Thanks for the heads-up!
Jan
Question again. If I look at say an 813, the max Va in the various modes is 2250 or 2500 V.
Yet, that is a DC spec, and if I use a SE choke loaded stage with say 2500V B+ (DC), the anode swings between close to zero and almost 5000V.
Does that then not violate the Va spec?
Jan
Jan
Two PL519's in parallel? They are actually specified for high voltage peaks rather than continuous high voltages, but hopefully they will survive. You could also ask @Lampie519 , he has used DIY direct-drive amplifiers for years.
I am wondering, those HV reg tubes with Va up to 25kV with Ia(max) 1.5mA.
Would they break if Ia was 25mA peak?
Look at the heater power. 6BK4 6.3V 0.2 Amp , smaller than a 12AX7/ECC83
I have a 6BK4 here, and the cathode is miniscule.
That PD500 looks better though. 7.3V 0.3 Amp
The PL519 looks better than the 6HZ5 for continuous HV, since it has a plate cap. The Compactron socket (only) of the 6HZ5 would probably break down with continuous HV, unless you submerge the socket in silicone oil.
- Tubes / Valves
- Looking for high-voltage tubes
