AmplifierProjectTemplate
Name | <Project/Amplifier Name> |
Type | <Solid State, Tube, Chip, Push/Pull, etc> |
Application | <PA, Wine Tasting, instrumentation, test equipment, waking the neighbors...> |
Class | <A, A/B, B, C, D> |
Approx Cost | $100,000,000 AUD |
Designer | <Original Designer> |
Thread | <URL to the discussion thread> |
The Project
Introduction
Give a brief [1-2 paragraph] description of your amplifier.
Goals
What were some of your goals with the design of the amp? In the end, did you achieve them? If not, where did the design fall short of your expectations?
examples: I wanted to create a class A amp that produced THD 0.00001% at 1KHz but I only achieved 0.01%
Specifications
Name | Description |
Volatge Gain | value |
Bandwidth | Value |
Phase | Value |
Sensitivity | 8 Ohm: Value, 4 Ohm: Value |
S/N Ratio | Value |
Rated Consumption | 100W |
Idle Consumption | 100W |
Harmonic Distortion | %THD or plot |
Harmonic Spectrum | FFT plot/plots |
Square/Step response | Oscilloscope Trace |
Stability | Phase margin + scope traces into capacitive loads |
Output configurations | Can it be bridged? Parallel drive? |
Output Impedance | Value or plot/plots |
Schematic/Blueprint
Please attach schematics to this wiki page. You can then use the [IMG] tag to display them inline. Please don't be afraid to attach Gerber files to the page as well.
Note: There is a bug in the wiki right now where you can't add attachments to a wiki after 30 minutes.
Bill of Materials
Either list them in this section or attach a file to the page that people can download.
Note: If this project uses other projects as components (maybe this is a full build and uses an amplifier and PSU from other projects, please list them here).
Simulations and Analysis
Embed the images for your simulations here along with descriptions for each of them so people know what you're talking about.
Construction (Steps / Tips / Notes)
Is there anything peculiar about the design that a builder might want to know about? List them here? Or do you just want to give us a step-by-step build plan; that works too.
Project Modifications
Do you have some small modifications to suggest for the project that could improve it? Please list them and tell us why they improve the design. If this is discussed in a thread, please link the thread URL here....
Modification 1
Cross the streams!
Modification 2
Install a flux capacitor!
Code for this template (copy/paste)
To create a new amplifier project, simply copy the text below, create a new wiki page/article (preferably with the name Amplifier:ProjectName) and paste the text into your new page. Voila!
Code:
[TABLE] | border="0" cellspacing="5"
| [B]Name[/B] || <Project/Amplifier Name>
| [B]Type[/B] || <Solid State, Tube, Chip, Push/Pull, etc>
| [B]Application[/B] || <PA, Wine Tasting, instrumentation, test equipment, waking the neighbors...>
| [B]Class[/B] || <A, A/B, B, C, D>
| [B]Approx Cost[/B] || $100,000,000 AUD
| [B]Designer[/B] || <Original Designer>
| [B]Thread[/B] || <URL to the discussion thread>
[/TABLE]
[H="1"]The Project[/H]
[H="2"]Introduction[/H]
[H="2"]Goals[/H]
[H="2"]Specifications[/H]
[TABLE] border="0" cellpadding="2" cellspacing="0"
| class="tcat" | Name
| class="tcat" | Description
| Volatge Gain || value
| Bandwidth || Value
| Phase || Value
| Sensitivity || 8 Ohm: Value, 4 Ohm: Value
| S/N Ratio || Value
| Rated Consumption || 100W
| Idle Consumption || 100W
| Harmonic Distortion || %THD or plot
| Harmonic Spectrum || FFT plot/plots
| Square/Step response || Oscilloscope Trace
| Stability || Phase margin + scope traces into capacitive loads
| Output configurations || Can it be bridged? Parallel drive?
| Output Impedance || Value or plot/plots
[/TABLE]
[H="2"]Schematic/Blueprint[/H]
[H="2"]Bill of Materials[/H]
[H="2"]Simulations and Analysis[/H]
[H="1"]Construction (Steps / Tips / Notes)[/H]
[H="2"]Project Modifications[/H]
[H="3"]Modification 1[/H]
Cross the streams!
[H="3"]Modification 2[/H]
[H="1"]Reviews[/H]
[H="2"]Review 1[/H]
Rock on!
[H="2"]Review 2[/H]
Duuuude.....
[H="1"]Build Threads[/H]
Have you built this project? If so, please add the URL to the thread that you started to show off your build.
[LIST]
[*]URL to my uber build 1 thread
[*]URL to my super dooper build 2 thread!!!
[/LIST]
[H="1"]Related Group Buys[/H]
[LIST]
[*]Thread 1234
[*]GroupBuy:PSU
[/LIST]
This page has been seen 5,609 times.
Created by onLast updated by on
