upc1237 based ssr by bonsai?I see the speaker protection circuits, disconnecting speakers as soon as d.c is present in the output and connecting speakers again when d.c stops.
How we can latch the last(fault )condition,no speaker reconnection up to power reset.
Here are files for you my friend, if you decide to build..Thanks prasi,please give us a Christmas 🎁.
No worries,after Christmas is ok!
Merry Christmas ⛄ to all of you!
Any of the following will work fine. 5.08mm x 7.62mm pitch.Prasi:
A follow-up question: what part did you specify for B2?
Regards.
https://www.mouser.in/c/semiconductors/discrete-semiconductors/diodes-rectifiers/bridge-rectifiers/?if - forward current=1 A&mounting style=Through Hole&package / case=DFM~~DIP-4&instock=y&sort=pricing&rp=semiconductors/discrete-semiconductors/diodes-rectifiers/bridge-rectifiers|~Package / Case
Also attaching slightly modified files, where in I have removed the solder mask for speaker traces and also added a pinheader for ground reference.
speaker protect and startup delay - mod-SSR-TRIAL1_2023-12-25.zip313.2 KB · Views: 79
speaker protect and startup delay - mod-SSR-TRIAL1-btm.png86.7 KB · Views: 199
Any changes to this design? Has it been proven to work?Any of the following will work fine. 5.08mm x 7.62mm pitch.
thanks very much
Whats the time on the turn on delay and how would I increase to say 15 secs?
Size R15, for 20-25ma through optocoupler
Monk55 (et. al.):
Yes, I saw that on the pcb but don't understand what it means. I'm looking for actual guidance on how to take the appropriate measurements.
Scott
- The diyAudio Store
- Speaker Turn On Delay and DC Protector Board Set (V3)
