A new pair of Silbury speakers: newbie questions
I’m starting this build because I’m a newbie and I would like to ask some simple questions on how to build speaker cabinets.
Today, together with my friend, we did some trials on a junk piece of wood.
Is this correct, or the 45 degree should start from the inner part of the speaker?
Build in progress!
Reactions: 1 user
Those nutserts work great and are better than T nuts. The brass ones should use brass bolts too. If you mix metals there is a galvanic reaction that can weld the bolt to the insert. Much better than just screws into wood as they can be removed and reused without issues of the wood getting torn up.
Reactions: 1 user
