I wouldn’t suggest placing the phone near your amp while connected to speakers either, although I know what you’re talking about from accidentally having done that once on one here. At the time I was attempting to use the phone as a hotspot in a basement.
Amps and speakers aren’t supposed to make those sounds.
Tiny Ferrite cores on output transistor pins can help too, haven’t tried on smaller transistors.
Yes, all mains peaks are clipped these days because of all those rectifiers that start to conduct at the mains peak, in all those myriads of consumer equipment in our homes.I see symmetric distortion, kind of clipped peaks. This is normal nowadays. And gives H3,H5 etc, but not H2,H4 harmonics.
Jan
Hum?Except when the hum is 1uV at the input and it is amplified; then that 20uV at the speaker IS the hum.
Only to the sensitive measurement equipment.
That 20 uV would be 0.1 nW at the 4 ohm loudspeakers. 100 dB below what SPL 1 W would produce.
Ferrite beads are very effective, and I have a bag full of. Their effect was evaluated with BJT CFP output stage, which is prone to severe oscillation with modern BJTs. Ferrite beads at emitters pins would squash oscillation but would also introduce nonlinearity, very well seen as a jagged rising slope of a square wave signal. I use ferrite beads at DC supply inputs of my DIY measurement gear.Tiny Ferrite cores on output transistor pins can help too, haven’t tried on smaller transistors.
I was replying to another post. You miss the context, you miss the point.Hum?
Jan
That jagged rising slope is not from nonlinear beads, it's an instability.Ferrite beads are very effective, and I have a bag full of. Their effect was evaluated with BJT CFP output stage, which is prone to severe oscillation with modern BJTs. Ferrite beads at emitters pins would squash oscillation but would also introduce nonlinearity, very well seen as a jagged rising slope of a square wave signal. I use ferrite beads at DC supply inputs of my DIY measurement gear.
It makes sense, you squashed the oscillation with the beads but it isn't 100% stable on fast edges yet.
If you put on two beads the jaggies will most probably be gone, but they don't do any harm anyway if the square wave has spectra beyond the audio band.
Jan
Ferrites for this sort of use typically have effect between 10MHz and 500MHz or so, so nothing non-linear in the audio band at least. They have a partly resistive R.F. behaviour (i.e. are lossy at R.F.) making them good at reducing Q and stopping unwanted resonances.
Note there are many types of ferrite materials with different properties, not all suitable for EMI suppression, and DC current level affects properties too. Datasheets are your friend!
- Design & Build
- Electronic Design
- Circuit design for EMI immunity
