Dynamic range exhancer for an FM tuner
In case of relatively weak reception, but not so weak that click noise dominates, the noise spectrum at the output of a frequency demodulator increases with 20 dB per decade. Meanwhile, most audio signals have most of their spectral content at low frequencies.
You can therefore gain a lot in signal-to-noise ratio by emphasizing the high audio frequencies in the transmitter (pre-emphasis) and correcting for that in the receiver (de-emphasis). Unfortunately, different parts of the world use different standards for the pre- and de-emphasis: 75 us or 2122 Hz in the USA, 50 us or 3183 Hz in Europe.
While pre-emphasis/de-emphasis works well for FM mono, it is far less effective on the left minus right signal of FM stereo. Hence the huge noise increase when the signal is just strong enough to switch a radio to stereo (assuming an old-fashioned FM stereo radio, nowadays radios usually gradually fade from mono to stereo to make it less objectionable).
Reactions: 1 user
Yes.
That is, in real life, they put a multiband compressor/clipper before the transmitter that ensures the sound coming out of the radio has little resemblance to the original, but the correction in the transmitter itself is indeed an accurate complement of the roll-off of the first-order de-emphasis filter in the receiver up to 15 kHz (the normal audio bandwidth of FM broadcasting).
Reactions: 1 users
I measured the response of a local broadcast station here all the way from the mixing console to the audio outputs of a Sony ST-SB920 tuner on several occasions. The compressor the station then had left small signals unharmed, so I measured with small sine waves, -40 dB or so, and of course in the middle of the night, assuming there was no one listening anyway. It turned out that a friend of a colleague at the radio station had actually listened to it once.
Reactions: 1 users
My wife did present a radio program on one of the local fm transmitters. We streamed the audio at 192kbit through an english server. that stream was picked up by the local studio (30sec delay), processed by the orban and the stereo mux signal was sent to the local mountain transmit station using small transmitter.
The mountain did not have telephone cables or fiber, not even an electricity meter as the electricity company did not want to climb the mountain for meter reading. Radio as a pure art....
Joined 2010
The Studer A726 uses a coaxial cable for frequency to phase difference conversion, followed by a multiplier-type phase detector. It should be nearly perfectly linear when used with square waves (and the limiter produces square waves).
It's off topic anyway, because I think this thread is about undoing the damage done by dynamic range compression on the studio or transmitter side.
No, go for it.
It's good very good information.
Joined 2010
Before tearing into the tuner I'd probably ask some questions of the radio station you wish to listen to. I would not be entirely shocked if the FM broadcast is just their internet stream (which is usually pretty low bit rate MP3) pumped through an FM transmitter.
Tom
Well, since my goal is to use the FM tuner... I could take the Internet Stream via an Android device, hopefully synthesizing a 24/192 signal, send that to the DAC, then drive that to an RF transmitter of sorts -no antenna, just the signal, drive that to the input of the FM tuner and then use the expander.
Voila!
Reactions: 1 user
Joined 2010
Yes.
Wasn't that the point of FM Dolby?
I got a Marantz receiver with an FM Dolby deemphasis switch.
Joined 2010
In my area most FM transmitters are semi ligit, they pay VAT but there is no official spectrum allocation. As the link from studio and processors to the actual transmitters is mostly analog, the deviation is manually set, with the resulting possibilities of error. Some operators do not even have a deviation meter. The only thing they know to do well is RF output filtering with cavities as they combine more freqs on a single antenna. any possible mixup to the airtraffic band should be avoided at all cost, as that results in a direct action of the authorities. As long as the transmitter power stays below 1kW the operators are left free. A bit of a leftover of the franco dictator days, when illegal radio was the basis for the current political parties .
We were close to France, well in reach of the AM stations.
The French radio stations in Le Roussillon would broadcast some shows in Catalan and played the La Marseillaise in lieu of La Santa Espina. Everybody understand that, but La Guardia Civil couldn't just cross the border.
Somethings Franco just did not allow.
In fact these days the FM multiplex signal is synthesized using a 192khz dac to provide the 57khz bandwidth of the FM stereo encoded signal. All the soundprocessing and multiband lookahead compression is done in the "processor". So ready to go into the FM transmitter.
Reactions: 1 users
Joined 2010
Tom
I hear the difference by tuning to different stations... some sound quite realistic, some sound "flat". So, I honestly think the tuner can sound quite good. I do plan on having a guy go through it and make sure it's all up to spec.... although the guy I bought it from did a pretty good job on maintaining it.
Reactions: 1 users
I have a KT-8300 which is the same design as the 9900. I'll knock it because ...
I found mine to not be anywhere selective enough to tune into my favourite FM station which is sandwiched between two more powerful adjacent carriers.
KT-8300 sits on the shelf, needing a fine filter upgrade. I also found it to overload, have images. It has no RF FE AGC. MOSFET-G2 hard-wired for max gain and there are two gain stages. KT-917 is a better design as it uses a balanced mixer. I do not know why Kenwood EE's did not use AGC whereas the Yamaha EE's managed to get it right.
I am using some Yamaha T-85 tuners which perform much better for my locale. I have a large FM yagi on the roof with a rotor.
The KT-8300/9900 tuner has a deviation meter on it, very few do, scan your dial and see where they are. Some actually over modulate.
The stations that sound a bit lower in volume are probably not as compressed or over modulated.
I offered my services a couple of times to repair our local LPFM stations transmitter (CFGI) when it was down. Its a Nuatel VS1.
These devices are quite sophisticated, they have built-in spectrum analyzers, to monitor modulation, power SWR ect and a web page for remote control. Lots of ways to configure them.
I know from my experience the CFGI radio station has very little knowledge on VS1 configuration. It was configured once by a tech/EE at first install and never touched again.
Crap when I designed a Si4735 radio and wrote the PI decoding code, I found out that many well known stations in our area, owned by Corus, etc did not even have they RBDS setup correctly. One sation was putting out "FFFF" pi code which is reserved for Mexico. :) So based on my experience the stations are all over the place in regard to proper configuration. Nautel have excellent product support, they walked me through a complete upgade to the VS1 software and a hardware upgarde as well.
Long live FM radio, for me, streaming sucks the big one. But CFGI does stream, it does not sound anywhere as good as the over the air transmission.
  • IS11003B_VS-NVLT_Operating-with-Orban-Inside.pdf
Joined 2010
No. it's not a matter of signal strength. They're all pretty much up fully deflect the signal strength meter.
I guess I ought to look at other meter. It does multipath or deviation.
Comparing two stations, a good sounding one and flat sounding one... both show the same multipath, but the good sounding one shows more "dynamic range" for deviation.
I'm using a powered indoor antenna.
