Dynamic range exhancer for an FM tuner
Joined 2010
Offtopic:
when searching and listening to the digital versions of this song I found about four different releases (from the same performer), each of them mastered and sounding different...
And then you got the "re-mastered" copies... and the different pressings of the LP.
Then you got Santana's Black Magic Woman... the first LP pressings had the L/R channels backwards. They didn't realize this until they went to cut the CD. The congas appear to the left, and back of the left speaker... in my LP.... but releases after the mid 80s, all have them to the right.
Reactions: 1 user
Joined 2010
OK, some good news.
(1) I opened up the box and used some Deoxit on the switches, they work perfectly now.
(2) As I was in it, I saw it is made up of a mother board with some plug in boards. The boards use old style -ie: large- plastic plug in connectors. The boards are kept in place with a sculpted foam block. I take it the factory was aware of the rather fragile nature of the connectors.
(3) The leftmost board, looking from the front, handles the expander. If I wiggle it the left channel comes and goes. So, I pulled it out and cleaned out the connector (which looked clean), it did't make much of a difference, so I think the issue is on the other side of the mother board.
(4) The next two boards are the correlator boards... #2 is right and # 3 is left. I sent pictures to my guy and he replied "caps are really early Nippon Chemi-con and low density fiber circuit boards, Problem with those is low trace adhesion. Luxmand had that problem on early 70s stuff". He ought to know, he's a Luxman guru...
(5) Anyhow the interior is amazingly in good shape. So, I sort of played with the foam block to apply some sideways pressure on the expander board and closed it up. I'll take to my guy when he gets free time. I really don't want to mess with this thing. And it works.
LISTENING
(1) The processing is based on the level of the signal. The tuner has a volume control so that affects the level of the signal fed to the processor.
(2) I got the processor in the EPL ( tape deck ) loop of the preamp. So, I can do comparisons quickly with the preamp's remote.
(3) The autocorrelator is in essence a smart high and low cut filter with the knee frequencies adjustable from the front panel knobs. It robs the bass from the tuner, regardless of the setting. I can hear the filter for the treble as well, but I had the tuner set up to FM Muting and the signal is strong enough, i don't have a noise problem. Because of the bass cut, I decided to keep this circuit disabled.
(4) The expander is noticeable. You set it so the front panel LED turns on and off with the volume of the signal. I can really hear it... mostly you notice the loud levels do get louder while the soft levels don't change. It's very obvious. Just to be on the safe side, I turned off my eyes, so I couldn't see the preamp settings, and turn on and off the EPL loop. Didn't count, so I didn't know what setting it was set to... so I sat down to listen.
As I toggled the remote to enable/disable the EPL loop, I could hear a difference, quite clear. I did listen in some 20 second intervals, so it gave me the opportunity to compare the same song ( many songs ). This time I counted as I was switching, but with my eyes closed, I did not know which was which. At some point, I decided that one of the setting did some a little bit louder on the peaks.. when I opened my eyes I noticed it was indeed the Phase Linear... the important thing is that the lows didn't sound louder. So, I guess the dynamic range was increased.
It does sound better. Quite subtle but it does the trick nicely.
Have not used it with the LP as a source, but, I doubt I need it.. because it does sound very quiet already... but, I guess I'll see if I can find a "noisy" LP and try that out.
GOING FORWARD
I got to see if I can clean out the dbx118.
After that I will take both to my guy and fully clean them out... might even change the opamp on the analog board of the Phase Linear.
Also, will look at the Pioneer units.
Here's the porno. The left most picture is how I left the foam so it puts some force sideways on the leftmost board.
Reactions: 1 user
Joined 2010
OK, so it's been rather busy chez moi.
The Super Duper Amp went again... and for some reason the woofer also went. Had to make arrangements to get them fixed.
Go Figure. If I wanted no excitement I'd get a Bose (*)
In the meantime I got a hold of another F4, so there's the plan to drive them with a BBA3.... woohoo, we'll see... and a couple of "back of the caboose" balanced preamps are making their way chez moi. But, I got work getting in the way and trips and family stuff.. so the project to plug those big 50 watt resistors, mounted on those BIG heat sinks, and use them to mate the output of the Sissy to the input of an F4.... will also have to wait.
Something did hit me today... in the 70s, the cowbell was to country rock what the whistle was to disco. Just thinking... Loggings and Messina, Valhevalla, has a very good cowbell.. "more cowbell"... and Donna Summers has more whistle that the entire police department in East London.
OK. so tuner and expansion decompression. The Phase Linear does a magnificent job. I only use the "peak unlimiter" not the "auto correlator". You can really hear it. Set the threshold so the LED just flashes about half the time and you're off the gates. My preamp has a remote so I can turn the "tape loop" on and off and you can truly hear the different, it's not subtle, it's obvious and it makes it so much better.
With most digital sources, it's not needed since I tend to listen to stuff with sufficient dynamic range and the Macho 252 SIT and my speakers just never seem(ed) to get loud enough to do a "peak unlimited" 24/96 file any justice. I also haven't played an LP through the PL... but I'm happy with that sound so I have not messed with it.
Meanwhile, I have not had the chance to spend much time with the dbx, sorry but there just hasn't been much time. Coming out of retirement stole my free time with a vengeance. I hope to get down with the dbx sometime in September, by then I should be settled a bit more... phono, preamp and amps and speakers.
Someday, I will listen to music... not worry about the lights, cables, switches, out of kilter balance and smoke.
(*) As a matter of fact, I did get a new car at the end of March. A nice, spiffy Accord Touring sedan with the "Bose" logo "adorning" on the tweeters on the A pillars. We haven't put that many miles on it. Today I reached 240 miles... so I had the Android phone cranking some downloaded 24/96 Tidal tunes... and decided to crank some Donna Summer. DEEESCO! Yikes, those tweeters are painfully "tweezy".... grating... Now, I figure most people will never notice, indeed they might think that's how music is supposed to sound... but we are AUDIOPHILES... we know better. I wonder if it's even worthwhile to replace those tweeters... this is not an Acura ELS after all.
The FM modulation system acts as a comprssion expander by itself. By using an RF transmission bandwidth much larger than the audio bandwidth, it exchanges that for S/N (claude shannon's theorem) , also helped with some pre-emphasis. So a 35dB RF S/N results in almost 55-60dB S/N audio. After that only improved antenna S/N improves the demodulated audio S/N. One of the best FM tuners capable of extreme high S/N is the panasonic STG7, having an integrator type count detector preceded by a frequency tripler, such that a signal results with a 800khz deviation. Getting an 11el yagi plus rotor really helps. The problems these days could the the quality of the modulators and the signal path from the studio to the transmitter, and the extreme use of fm processors to try to win the loudness war.
Ah; that's interesting, makes sense to me.
I've just got my hands on an audiolab 8000T, which has exactly the same approach you describe (IF doubled to 21.4MHz in the 8000T). It is very quiet.
Reactions: 1 user
